Old 10-20-2007, 11:00 PM   #1
Need help with outside drain...
Hi everyone, my house has a drain in the backyard, and this drain is leading to inside of the house, and was tied in to the drain stack. Was like this, I purchashed the house a bout a year a go. I been noticing, each time it rains hard, I have a puddle inside my basement on the floor drain. What can be done to sole this problem? Thanks
helpless handyman is offline   Reply With Quote
Old 10-21-2007, 02:01 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You need to open a clean-out on the main drain line and snake it out with a heavy-duty plumber's snake (which can be rented) from the house to the street if you're on sewer or to the septic tank if you're on a septic system.
If that doesn't clear it and if you have sectional drain line underground, such as cast iron, you may have roots in the drain line and it will need to be roto-rootered. If you have roots in the drain line, roto-rootering will only last a couple of years at best, and you'll have to do that over again, until you replace the underground sectional drain line with "glued" solid plastic line that won't allow root intrusion.
If you hire a drain cleaning company or a plumber, make sure that you hire one with a video camera to inspect inside the line to show you specifically what the problem is.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-21-2007, 07:50 PM   #3
Okay, got it and Thanks. My question is how can roots get into cast iron drain pipes and not to plastice drain pipes?
** Also what type of drain pipes is used for the drainage from the house to the street? No septic here, city sewer. Is it that black plastic pipe I see everywhere?
More On This Topic
If your sink drain is clogged and you’ve already tried plunging it, which everybody knows how to do, you’re probably going to need to go a little further and snake out the drain line. I know this freaks out a lot of people, but it’s... Read More »
Ok. We're outside the house now. We're going to talk about where we tie these to the existing sewer line. And, you remember that we had Arizona Blue State come out and mark the ground on the street to give us an idea of where this sewer line is. Where it... Read More »
Cleaning a bathroom that empties into a septic system requires more thought than one that feeds into a city water supply. One does not want to mess up the required bacterium and percentages needed in the septic tank to keep it properly balanced. You do... Read More »
Few things are more annoying than washing your hands and discovering that the water level won't go down. However, if you take a few preventative measures, you'll reduce your odds of having to call the plumber. Read More »
If you like putting things together with your hands, a career as a plumber might be for you. Plumbing is a highly skilled profession and one that will always be in demand. Plumbers install, maintain and repair the systems that keep our water flowing... Read More »
Old Type Bath Drain Tool Junkie Plumbing 4 09-26-2007 04:05 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
