Old 10-31-2009, 01:04 PM   #1
Default Need help with a leak
Hello, I was wondering if anyone can help me with a problem I am having in my basement. I just bought my house in August and just a week ago we have found water coming though the basement through a hair line crack after a rain big rain. We had a plumber come look and he thinks it has to do with the drain tile under the basement. Now he wants to charge 650 to jet the pipe and to use a camera to look at the pipe. Now I am wondering 2 things. One is it really going to caust that much to do that and for 2 do you think that is it that is causing the leak. Now we have no cracks in the walls so the foundation looks great. Now we have noticed a kind of dirt in one of our toilets but not the other and not the sinks I was wondering if that has anything to do with that. Any help would be great. Thanks, Jen
SmallRiver is offline   Reply With Quote
Old 10-31-2009, 05:44 PM   #2
Civil Engineer
I wonder what type of drain line you have running under the basement. Is it a sewer line, or a floor drain? First question I would have is whether or not there is water in the line, I am having trouble picturing an exterior drain line running under the basement.
As for the cost, well I don't really understand your question. If the plumber plans to charge you $650, that is what it will cost, unless of course you solicit another bid. If you are asking if it is worth it, that is a totally different question. As for viewing the drain line with a camera, that sounds like a reasonable plan, to see if it is blocked.
More On This Topic
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
A tank like this cost you about $1,500 including the pipes, including the faucets and everything you want to use for it. We will just follow now the line of this rain water, how it comes into our house, and you can see how we use it. So what you see here... Read More »
Reducing Allergies: Mold
Reducing Allergies: Mold by Expert Village
Mold is something that many people that have allergies react to. I find that if you have a very humid house, or you're in a bathroom, or any place that has a lot of humidity, mold tends to grow. It's the dark stuff that grows on your shower walls that... Read More »
Hi, I'm Jeremy Blackwell I'm here today to help you get started on your basement remodel project. This is a GFCI outlet that's required in bathrooms. The reason this is required is because if any water were to just drip on the outlet or if a hair dryer... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will show you how to check for engine coolant leaks. As you take a look at your engine coolant reservoir, you will notice that there are several hoses coming and going from your... Read More »
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 03:26 PM
Persistent Leak - Chimney or Roof? CMoorhead Roofing 10 01-08-2009 07:45 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 08:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 10:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 03:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
