Need Help With Kitchen Faucet Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2012, 07:31 PM   #1
Smile
Need help with Kitchen Faucet installation
I am a recently new home owner and completely novice handy man and the other day I had the bright idea to change out my kitchen faucet after it started leaking to something a little more modern. After you tubing some do it yourself videos I figured the challenge would be simple and it was altogether fairly easy except for one part. The hot water has a shutoff valve that will allow you to connect to a supply line. However, my cold water has a very odd shutoff valve that will not allow me to connect it to a new supply line that is already on my faucet because it has a supply line connected to the valve that is unable to be disconnected. I don't want to break anything that I am going to regret later on so I was hoping I could get some friendly online advice! Pictures to come, gotta shrink the files because they are too large.
Getzlaf1579 is offline   Reply With Quote
Old 04-21-2012, 07:34 PM   #2
Picture of Cold Water Valve
Here is the valve
Old 04-21-2012, 07:37 PM   #3
Here is a picture of the hot(left) valve and cold (right)
Here is a picture of the current supply lines and valves.
Old 04-21-2012, 07:43 PM   #4
DIY staff
Rewards Points: 7,174
I can't help much---I've run into those things twice and had to slit the side of the plastic using a multi-tool and remove it by breaking off the slit fitting----
Someone here must know the secret of removing those early push on fittings---Mike----
ben's plumbing (04-22-2012)
Old 04-21-2012, 07:59 PM   #5
Thx for the reply!
Yah, I don't want to create a bigger problem for myself. I'm hoping someone might now the easier way to remove that valve and if I should expect for the piping to have some threading on the end that I can connect a new valve to or if I'm going to have to solder on a threading to the end.
An easy fix I suppose would be to buy a connector for the old supply line to the new supply line that is already on the new faucet i bought. However I would like to replace the old one so that my water pressure will improve.
Old 04-21-2012, 08:15 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The fitting at the top of the supply lines look common enough.Could you not just unscrew them from the old fauct and on to the new one?
sublime2 is offline   Reply With Quote
Old 04-21-2012, 08:24 PM   #7
Rewards Points: 256
Looks like you could, but I dislike reusing supply lines.
Buy yourself a new shuttoff and supply line when you buy the faucet.
You might get by without replacing those, but running to the store in the middle of a plumbing project is never fun.
I always buy what I might need, then return after project is finished.
michaelcherr is offline   Reply With Quote
Old 04-21-2012, 08:41 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 788
I have only dealt with that type of a couple of times too. Basically, you have to out smart it.
Like Mike said, it's an early version of a shark bite fitting so its just pushed on the copper stub. Once you get it of install a 5/8 comp x 3/8 comp angle stop and your good to go.
I shouldn't have to say this, but turn off the house supply and relieve the pressure before you tinker with the valve.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-22-2012), oh'mike (04-22-2012)
Old 04-22-2012, 08:26 AM   #9
Rewards Points: 582
unkindness of ever sort till it comes off
The Following User Says Thank You to ben's plumbing For This Useful Post:
kitchen faucet sudden stoppage amakarevic Plumbing 4 08-31-2011 10:47 AM
No water from my kitchen faucet? bizzy1028 Plumbing 7 06-07-2011 02:16 PM
Kitchen faucet: did I mess it up? mikew Plumbing 3 06-28-2010 02:35 AM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
