Need Help With Foul Odor From Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2006, 10:06 AM   #1
Question
Need help with foul odor from bathroom sink
When water is turned on in sink the foul odor seems to come from the overflow. I have checked the p trap and it seems to be alright. What could be causing this problem?
Jackhammer is offline   Reply With Quote
Old 06-05-2006, 11:11 AM   #2
Have you completely removed the p-trap and cleaned it out?
Is this sink vented? You may have sewer gas coming in if it is not vented properly.
redline is offline   Reply With Quote
Old 06-05-2006, 01:11 PM   #3
Yes, the sink is vented and yes I have removed the ptrap. From the ptrap there is a 45 then a 90 going to the rooftop. The ptrap had water in it to prevent the smell so I can't understand how it's getting through. The sewer gas is definitely getting through some way.
Old 06-05-2006, 01:17 PM   #4
Could the vent possibly be stopped up?
Old 06-05-2006, 01:32 PM   #5
Does the sink gurgle when the water flows down the drain?
If the vent is plugged then the water will gurgle.
You may have some other debris that is in the overflow. Put some baking soda in the overflow and then pour some vinegar down after. This will foam up and it may clean out the overflow. Follow this up with some hot water to flush out the overflow.
Old 06-05-2006, 02:01 PM   #6
Tried the baking soda and vinegar trick already, didn't work. I filled the sink full of water and the flow from the overflow seems alright. Also, there is no gurgling when water is released. Ever once and again the drain becomes slow but after a couple plunges it's alright for a couple months. The drain that is, the odor never leaves. Any other thoughts?? I'm stumped....
Old 06-05-2006, 02:05 PM   #7
Are you on well water or public water?
Old 06-05-2006, 02:08 PM   #8
Public water..
Old 06-05-2006, 02:12 PM   #9
If you cover over the overflow, do you still have the smell?
Old 06-05-2006, 02:14 PM   #10
I'll have to try that and get back with you later. Thanks for your help thus far.:confused:
Old 06-05-2006, 03:05 PM   #11
Master Craftsman
Big Dave's Avatar
If the smell is only coming from the one bathroom sink then I would guess that the vent is partially blocked. Maybe a bird or squirrel has built a nest in the top of it.
Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Bathroom sink drain sieve satchmo Plumbing 3 06-07-2007 12:28 PM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 10:14 PM
bathroom tub and sink semi-clogged bobo Plumbing 2 04-19-2007 12:24 PM
bathroom sink supply line height bluebee1314 Plumbing 2 03-28-2007 06:47 AM
