Need Help Fixing A Plugged Shower Drain. - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-28-2011, 10:29 PM   #1
Need help fixing a plugged shower drain.
We've been having trouble with our tub/shower in our apartment not draining. Our shower is the type that has the little lever on the overflow plate to open and close the drain. Yet it is not the pop-up style. The drain opening at the bottom of the tub is just a clear open pipe. Considering this I thought our shower is the plunger style where the drain lever moves a brass plunger at the bottom of the overflow pipe to close and open the drain.
However, when I unscrewed the overflow plate and pulled out the linkage assembly I instead saw a spring at the end rather then a brass plunger. Here's a photo.
Right now the whole spring linkage assembly pictured above is out of the tub and the tub is still not draining. Is there suppose to be a plunger at the end of this the may have broken off? I also tried pluging the overflow pipe with a wet rag and plunging the tub but that didn't seem to help either. I've also tried passing a ZipIt all the way down the drain pipe and overflow pipe and neither pulled out any clogs or seemed to hit anything
Anyone have any idea what's going on?
aireq is offline   Reply With Quote
Old 08-29-2011, 05:37 AM   #2
DIY staff
Rewards Points: 7,174
That spring is used to lift the drain pop up.
You must have removed the part to get the zipper into the drain.
More info needed--did that lever ever work?
How old is the building?
Do you have a P-trap or a barrel trap?
Do you own the building?
Is the zip thing long enough to reach the P-trap?
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 07:27 AM
1 1/2" shower drain tlynn Plumbing 3 02-25-2010 05:09 PM
Installing stand-up shower in finished basement without existing drain notenoughtime Plumbing 3 05-16-2009 11:59 AM
Plugged master shower drain tam331 Plumbing 1 12-06-2006 11:33 PM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
