Need Help Fixing Leak To Delta Monitor 1400 Series Shower/tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2010, 06:16 AM   #16
Hi I am in the process of replacing my cartridge and have a major problem. I used the advice above and was finally able to remove the bonnet after investing in a strap pliers, but not before first trying to remove it with regular heavy duty pliers. I think I twisted too much and now when I went to turn the hot side of the water back on, the water is spraying from the underneath part of the main housing assembly that the cartridge sits in! The cold water was turned back on with no issues. How would that leak or crack be fixed? Is soddering it the answer? Anyone else ever have this happen?
mccusker is offline   Reply With Quote
Old 05-01-2011, 05:26 PM   #17
what is the yellow plastic peice called that is shownin in star987 pic
what is the yellow plastic peice called that is shownin in star987 picture of the valve stem. I need to replace that peice for two of my shower handles. Can anyone help me out by tell me what it is called and if any major home repair store has the part?
Sunny
ssraheem is offline   Reply With Quote
Fixing a threaded leak without disassembly love4god Plumbing 6 05-21-2007 07:57 PM
