Need Help With Drain Instolation On A Dual Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 11:00 AM   #1
Need help with drain instolation on a dual kitchen sink
I am trying to install new drains for my double sided kitchen sink but I still have water that continues to leak out around the bottom of my drains where the black rubber seal is that is flush with the under side of the sink. Any advise and or help to what I am doing wrong? I do have plumbers putty that is around the sink on the upper side of the drain.
jdsskippy is offline   Reply With Quote
Old 05-12-2013, 12:49 PM   #2
Rewards Points: 2,038
Your putty is not sealing take it apart and make a snake out of the putty and wrap it on the underside of the stopper. Make sure when you push that into the hole that the putty is actually getting squashed out... Also do not move it as you tighten the bottom to the sink...
Help: Kitchen sink drain is clogged with grease cips Plumbing 5 03-16-2014 10:43 PM
Kitchen Sink Drain marcopolio Plumbing 4 12-03-2012 09:03 AM
kitchen sink wont drain turion Plumbing 15 03-16-2012 07:10 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Kitchen remodel, sink drain rework pinkertonpv Plumbing 3 02-18-2009 10:06 AM
