Need Help Creating New Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2009, 10:41 AM   #1
Rewards Points: 174
Need help creating new cleanout
Okay, so I was able to get the 3" cast iron clean out pipe from the main stack. I went and bought a 4" cleanout to attach to the old fitting. I figured I could use a 4" no hub gasket to join the cast iron pipe to the PVC. Low and behold, the outer diameter of the cast iron pipe is 5". I could not find anything at HD or Lowe's that would make the connection. One of the workers at HD told me to stick a 4" PVC pipe into the opening and stuff the sides with oakum and then connect the new cleanout to the 4" PVC. I wasn't so sure about that so I am posting the situation on the forum.
What would be the best way to resolve this situation? By the way, the reason why I needed a new cleanout is so that I can connect a 3/4" drain line from the macerating toilet I am installing in the basement.
Leoskee is offline   Reply With Quote
Old 08-13-2009, 12:19 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-14-2009, 08:13 AM   #3
Rewards Points: 174
Thanks. I found a plumbing supply store near my house. I'll check them out later on today.
Connecting Outside Sink Drain to Main Cleanout dancobian Plumbing 7 06-03-2009 06:26 AM
Creating a soundproof wall question acyate Building & Construction 19 02-23-2009 09:10 PM
Standing liquid in cleanout TheOldMan Plumbing 1 12-11-2008 02:15 PM
Outside Cleanout cchong Plumbing 2 09-10-2008 10:14 AM
Can I attach a toilet to sewer cleanout? MnMan Plumbing 4 07-30-2008 08:14 PM
