Need Help With Capping A Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2008, 01:52 PM   #16
Rewards Points: 150
chicken lady,,,I live in Nebraska too. I would NOT trust the insulation only unless you have a ground heat pit also. Does the waterer have a electric outlet under it?? Can you either heat tape the line OR use a regular elec element heater like MOST waters had under them anyway??turned to LOW should be enough. when the wind blows and its 20-30 below to start with is NO time for a geyser. You CAN dig down with a spade yourself if you want and put a drain back curb stop in that line, then you dont have to do anything to it!!BEST if done in late summer when rains arent likely. Backhoes tear out more things than they fix,,,in MY experience!!
justdon is offline   Reply With Quote
How to protect 3/4" copper pipe passing through concrete Mike Warner HVAC 2 03-13-2008 12:37 AM
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 10:36 PM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 04:03 PM
Copper pipe for conduit? ricemg Electrical 4 01-23-2007 05:04 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 07:53 PM
