Need Help On Bathroom Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2009, 12:35 PM   #1
need help on bathroom pipes
My son installed what we were told at home depot shark bites on our bathroom shower pipes, but he is needing to take them off to put in longer pipe can this be done and how
arret15 is offline   Reply With Quote
Old 12-27-2009, 03:22 PM   #2
Remodeling Contractor
yes very easily. Send your son back to Home Depot to pick up the little plastic tool needed to remove these fittings. Same plumbing department not the tool department. You press this against the slip ring on the fitting and it will release. The shark bite fitting can then be used again on the longer pipe.
Old 12-28-2009, 12:13 AM   #3
Irrigation Contractor
Location: South Central British Columbia - The great White North
As Bob said it is very easy to remove the fitting with the proper removal tool. You didn't say it the pipe is copper or PEX. It is copper and if your son didn't bevel/debur and clean the original pipe, you might want to replace the original shark-bite fittings as well. Shark-bites have an internal O-ring that can be nicked or cut very easily on a cut piece of copper.
Water Guy is offline   Reply With Quote
Freezing pipes in master bathroom need a 993 Plumbing 8 11-29-2009 06:10 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
bathroom plumbing pipes, 4? oscarMadison Plumbing 4 03-04-2009 11:14 PM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 11:30 AM
