Need Help! AOSmith Gas Water Heater Is Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2011, 10:17 PM   #1
Need help! AOSmith Gas Water Heater is Leaking
I know the model and serial number but have no other information. Where can I get it so I can stop the water??!!
Harriett is offline   Reply With Quote
Old 08-04-2011, 12:25 AM   #2
Rewards Points: 352
The model has probably changed but a plumbing supply house can probably cross reference it for you. until you get it replaced turn off the gas or electric to it and shut the valve on the inlet (cold water) side. when the tank is empty it will stop leaking
plumberinlaw is offline   Reply With Quote
Old 08-04-2011, 12:54 AM   #3
Plumberinlaw, Thanks ever so much!
Harriett in North Carolina
The Following User Says Thank You to Harriett For This Useful Post:
plumberinlaw (08-04-2011)
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Water heater is leaking from the top lmlboone Plumbing 12 10-01-2008 04:18 PM
