Need Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2009, 12:42 PM   #1
Question
need help!
I am remodoing my bathroom and there is two peices of osb boards on top of the cement slab, if i take those boards out can tile over the cement or will i have problems with the toilet drain matching up right.
alayman is offline   Reply With Quote
Old 11-23-2009, 02:30 PM   #2
Remodeling Contractor
Why are you taking them out? Are they OSB or are they Advantec or other flooring materials. You can tile over the Advantec but not real OSB. What thickness are they? Are you talking about two layers?
Old 11-23-2009, 02:50 PM   #3
My flange for my toilet was leaking when I bought it n its all rotten. It is 2 pieces of osb on cement.
Can I just tile over cement n still have my plumbing fit together
Old 11-23-2009, 02:59 PM   #4
The tile needs to sit flush with the toilet flange. What depth you are dealing with is still not clear. Two pieces of 1/2 or 3/4 or what. You could use CBU over the concrete as a shim and to level as needed to get the heights right.
Old 11-24-2009, 02:35 PM   #5
oh my i am in over my head! I now have to gut my entire bathroom! there is black mold on the floors and behind the suround board by the bathtub! I got most of it under controle but i need to know if there is anyway to save the window. some dumbass put the window in the shower! the trim is ruined, but if i put killz paint on it would it help the water damage or do you know of anything else i could put over it or on it? its the only window in the bathroom and i dont really wanna take it out. any suggestions would help thanks!
Old 11-24-2009, 02:54 PM   #6
if u get online and read this i will try to post pictures tomorrow so everyone can see the headach i have to deal with! thanks for any suggestions!
Old 11-25-2009, 09:46 AM   #7
You need to use EDPM membrane to completely seal the exposed areas and sill of a shower window. Be sure you have positive drainage.
Old 11-26-2009, 05:44 AM   #8
What he said!
http://www.homeplumbingandheating.co.uk
thefonz22 is offline   Reply With Quote
Old 03-17-2011, 05:48 AM   #9
I thought EDPM membrane materials were used for roofing only?
www.centrallondonheating.co.uk
Man_Paq is offline   Reply With Quote
