Need Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 10:34 AM   #1
Need help!
Happy new year everyone, i got a good one for all of you hope you guys can help me. I just recently move into my home plumbing was all redone, and an upstairs bathroom was added. So i have a bathroom downstairs and a bathroom upstairs right above it. Sometimes when i flush the upstairs toilet my bottom bathroom sick fills up to the overflow then goes down and drains. Now i got it to stop one day when i had someone hold the drain down stairs shut and finger over the overflow and flushed upstairs and it worked fine but i had a bad incident last night a guest "used" the upstairs toilet and i think u could all guess what happend next. I really hope this is just a pipe that needs to be snaked. Anyone know what it could be?!!??
Ckb3216 is offline   Reply With Quote
Old 01-01-2012, 11:05 AM   #2
DIY staff
Rewards Points: 7,174
Tell us more----Does the downstairs bath have a tub?
Was the upstairs bath plumbed into the vent stack for the original bath?
Is the down stairs toilet affected?
Old 01-01-2012, 11:09 AM   #3
Yes both bathrooms up and down are full baths. Both have tubs. The bottom bathroom toilet and tub is NOT affected, only sink. When it does happen the sink down stairs fills up rapidly too! Then goes down slow. As far as your other question i have no idea, the plumbing was done before i moved in. So again so im clear. I flush the top toilet. And bottom sink fills up very fast till it hits the overflow then goes down slow.
Old 01-01-2012, 01:08 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Have the line cabled before something other than just water shows upm in your sink!
plummen is offline   Reply With Quote
Old 01-01-2012, 01:13 PM   #5
Rewards Points: 582
you said it don't happen all the time?only sometimes...
Old 01-01-2012, 01:54 PM   #6
Yes only when a solid goes down toliet paper etc.
Old 01-01-2012, 01:55 PM   #7
plummen's Avatar
Pipe is being over loaded,cable it out
Old 01-01-2012, 01:57 PM   #8
What could be jamming it up?
Old 01-01-2012, 02:03 PM   #9
DIY staff
Could be just a slow drain and cabling it will help---
could be that water is leaving the stack and entering the upper arm of the sink vent and entering the sink that way---
I'd pull the upstairs toilet and thoroughly
Rod that line---If there is blockage it's above the downstairs tub and below the vanity sink
Old 01-01-2012, 02:09 PM   #10
plummen's Avatar
Sounds to me like its using the lav as an overflow basically till the main line catches up then drains back out,it all depends on how the plumbing is tied together as to which fixture overflows first
Old 01-01-2012, 02:16 PM   #11
DIY staff
Hard to tell without a sewer camera or opening up the wall---
Old 01-01-2012, 02:18 PM   #12
Oh man dont even say open up the wall haha last thing i wanna do i have brand new tile up
Old 01-01-2012, 02:19 PM   #13
Thanks for all your help guys im going to take your advice and cable from upstairs, ill let you guys know what happends.
The Following User Says Thank You to Ckb3216 For This Useful Post:
oh'mike (01-01-2012)
Old 01-01-2012, 02:27 PM   #14
plummen's Avatar
Make sure to flush as much water as possible down the main while its being cabled to wash the trash out of line as possible while doing it.
Id run it all the way to street if possible,might be easier to run from upstairs to main floor first then from main floor to street.
Again it all depends on how the plumbing is laid out,talk to your drain cleaning guy and tell him whats going on with it
Old 01-01-2012, 02:33 PM   #15
Rewards Points: 582
has it done it from the start with the remodel...asking because had this same problem before at a location and found fitting installed backwards....
The Following User Says Thank You to ben's plumbing For This Useful Post:
