Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2011, 07:30 PM   #1
Need help
Hey,just enquiring if anybody could run me through how
To fix a leaking zucchetti tap?would appreciate the help.
Wet behind ears is offline   Reply With Quote
Old 10-07-2011, 10:34 PM   #2
Where is it leaking from?
VIPlumber is offline   Reply With Quote
Old 10-08-2011, 01:19 AM   #3
Constantly leaking out of faucet?need to know how to take apart so ICANN replace washer
Old 10-08-2011, 10:22 AM   #4
Since you haven't posted a pic, or provided a specific model, then the 2 most common ways to remove the aerator is to either use an adjustable crescent wrench (if it has the groves/slots) or a rag and adjustable pliers should do the job. It might just be finger tight as well, so try that first.
Old 10-08-2011, 11:00 AM   #5
Mark Potter's Avatar
Rewards Points: 150
The aerator wouldn't prevent water leaking out although have no clue about Totally square faucets something you see on a bathroom in a sailboat.
H|P Capital
Mark Potter is offline   Reply With Quote
