Old 05-21-2012, 10:44 PM   #1
Need guidance with pool booster pump installation
Hi guys,
Not sure if this is the right forum to post this question but I'm looking for someone to point me in the right direction.
I have a Hayward Phantom pool cleaner that requires a booster pump. My question is how and where do I install it?
I'm sure it goes after the filter into the return line but what gets me is that the flex tube that came with the booster is much smaller than the pvc that's piped all over. Do I need a special adapter to tap into the pvc? Does anyone have photos they can share of their setup?
I just need to be pointed in the right direction and I think I should be able to take care of the rest.
Thank for taking the time to read this.
CarlosHRNYC is offline   Reply With Quote
Old 05-22-2012, 02:12 AM   #2
If I help you out can I come for a swim and a steak on the bbq? The pool cleaner requires a separate booster pump and a dedicated supply line. The line runs 6" below water level in your pool to a special wall fitting. tThe fitting allows you to regulate the pressure to the cleaner so it runs properly. I haven't hooked up one of these units myself. I do have some experience with pool filter systems. Hopefully there is another plumber out there that has one installed in his or her own pool that can point you in the right direction.
sanec1 is offline   Reply With Quote
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 07:56 PM
What size wire for above ground swimming pool pump jshep105 Electrical 12 05-28-2011 07:43 AM
Ontario Canada Pool Pump Wiring cramar Electrical 1 05-18-2011 05:58 PM
how to wire 2-phase 240 pool pump doncomp Electrical 2 03-13-2011 08:17 PM
Pool Heat pump ryts4 Electrical 3 04-02-2010 06:53 AM
