Need Fitting To Pressurize Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2008, 09:03 PM   #1
Need fitting to pressurize gas pipe
Since Hurricane Ike, I had a plumber come out to test the integrity of my gas system. He pressurized it and it leaked down pretty quick according to him. He didn't determine where the leaks are but left that to me to save some money. I need to know what kind of fitting to use to pressurize the system to go bubble checking. I have access to an air compressor and can get to a 3/4" or 1" cap on my supply. Thanks, Chuck
Chuck@77550 is offline   Reply With Quote
Old 11-14-2008, 10:51 PM   #2
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Disconnect your gasline from the meter if not already done. You can put a reducer coupling onto your gasline at that point. A plumbing supply house will set you up with exactly what you need if you tell them the size of your gasline where it connects to the meter. So for instance, if your house line was 1-1/4" you'd get an 1-1/4" X 1/2" reducer and a short nipple. The supply house will have a gas test fitting that has a gauge on it. Just connect that to the nipple and you're set. Just be sure all valves at the appliances are turned off and the gasline is disconnected otherwise you might ruin your appliance(s). Around here we pump the house line up to 30psi and make sure that holds for at least 30min (inspectors here require 15min) before we call it good.
JDC is offline   Reply With Quote
Old 11-14-2008, 11:12 PM   #3
thanks for the help. will be under the house next week checking for leaks.
Thanks again!
Old 11-15-2008, 12:19 AM   #4
Registered User
Termite's Avatar
Use a spray bottle with soapy water. I use Dawn dish soap. When the gasline is aired up, liberally spray the fittings with the soapy water. Leaks will show up as bubbles that increase in size. Helps to have a flashlight as well.
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 04:33 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
Cracked PVC fitting in concrete DJupin Plumbing 6 07-29-2008 04:12 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
