Need Extra Thin Electrical Hot Water Tank... - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2015, 09:18 PM   #1
hohadcr's Avatar
Rewards Points: 316
Need extra thin electrical hot water tank...
Hi, in another thread i mentioned this as well....
Anywho. I have a very old and odd hot water tank so skinny that is now in a closet of 14"W X 16"D X 70"H.
It is very inefficient, someone told me it could be a heat exchange unit...
I need to change it and hopefully not have to do remodelling.
What do you know will fit in to such a small closet? except for tankless as they are pain....
hohadcr is offline   Reply With Quote
Old 06-13-2015, 12:55 PM   #2
Rewards Points: 46
Pictures? Don't forget the name plate
Cheers!
supers05 is online now   Reply With Quote
Old 06-13-2015, 03:00 PM   #3
Rewards Points: 3,837
You are in Canada so you might find one. In the US, thanks to the Jokers in DC you would be ready for a cigaret.
Seriously, good luck.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 06-13-2015, 03:27 PM   #4
Oso954's Avatar
Rewards Points: 1,114
In another thread you said it was an apartment. Are you in discussions with the landlord ?
In the US you can not change the water heater (or storage tank) without the landlords permission, and in many areas it would need to be done by a plumber since it is rental property. (Assumed from the word apartment) Not sure about Canadian law/code, but it is often similar.
Oso954 is offline   Reply With Quote
Old 06-13-2015, 09:43 PM   #5
It continues to amaze me what some people in rentals think the can do. So far I have been lucky with my tenants . I have explicit language in my leases that prohibit modifications, replacement or otherwise touching any mechanical, plumbing, electrical or structural system. I am very quick to respond to the tenants if they have an issue but otherwise you are renting what you saw.
jimn01 is offline   Reply With Quote
Old 06-13-2015, 09:57 PM   #6
hohadcr's Avatar
Rewards Points: 316
Here is the pics.
I work for the landlord no issues here. So ...
Still anyone knows of any water tank that is skinny like this?
Need extra thin electrical hot water tank...-20150612_195006.jpg   Need extra thin electrical hot water tank...-20150612_195016.jpg
Old 06-13-2015, 10:34 PM   #7
Rewards Points: 1,952
Is that a range boiler? From John wood page 30 of the pamphlet.
http://www.johnwoodwaterheaters.com/...s/en/J309C.pdf
Old 06-13-2015, 10:42 PM   #8
Rewards Points: 1,910
You can get a whirlpool or kenmore 30 or 40 gallon tall that is 18" diameter but that's the narrowest I've seen. I suppose you could stack two 20 gallon water heaters. Some of those are 16" in diameter.
But if you need 14" diameter then you just might need to add insulation to the water heater that is already there.
Old 06-13-2015, 10:58 PM   #9
http://www.kenmore.com/shc/s/p_10154...id=04233166000
18 inch
Old 06-14-2015, 01:56 AM   #10
Rewards Points: 46
Looks like one for sure. A whole lot like a storage tank, retrofitted.
Maybe I missed it, but I didn't see a tp relief valve. It's required in almost every jurisdiction in Canada. I'd be very careful with this, doing anything for a landlord means that you're on the hook for insurance if something goes wrong. Look up all the plumbing codes. (You'll probably have to buy he csa codebook + amendments if you don't already have one available)
I think you'll be stuck using an instantaneous hwh or a space saving tank. The other option is to make the space bigger. I don't think that those range tanks are Certified for a heating element, but I could be wrong.
Cheers!
Old 06-15-2015, 09:49 PM   #11
hohadcr's Avatar
Rewards Points: 316
Anyone can point me to the 16" or other 18" water heaters ??
Gros Merci....
Old 06-16-2015, 11:00 AM   #12
Special User
Rewards Points: 1,230
I'd be tearing out one of the walls next to that tank and framing in a new closet to accommodate a standard heater. 20g point-of-use water heaters cost as much as 40g standard heaters, and you'll need to buy two point-of-use heaters, doubling the cost. So you'd actually be saving money by demolishing and rebuilding a wall.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 06-16-2015, 04:14 PM   #13
Gros Merci....
Up above sears kenmore 18" Electric.
Old 07-06-2015, 10:55 AM   #14
hohadcr's Avatar
Rewards Points: 316
One more thing, the original heater is electrical. Would love to keep it electrical....
The Kenmore one is no longer available .. and it is natural gas...
Shoot, just want to avoid reframing....
Old 07-06-2015, 11:23 AM   #15
Special User
Why? Reframing is probably cheaper and easier than finding or jury rigging a heater to fit the non-standard space. 2x4s and drywall are cheap, you could have it done in an afternoon or a couple of evenings.
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
