Old 03-17-2012, 11:14 PM   #1
Question
need expert advise for new tub drain with oversized opening
Hi, my problem: my new custom marble tub has an opening of 3.25" (2" deep) and needs faceplate of 4". Made mistake when ordering. None of standard drains fit. Does anyone knows where I can find (or custom order) oversized (or conversion) parts? Or any suggestions how to silicon big opening with flat metal ring to make it standard...? Would appreciate ANY advise/suggestion! Please help!
Thank you.
need expert advise for new tub drain with oversized opening-tub-drain-plan.jpg
noraman is offline   Reply With Quote
Old 03-18-2012, 12:01 AM   #2
Moderator
Welcome to the forums! Moving you to "Plumbing" for better response thanks to an alert member (not me).
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Old 03-18-2012, 12:38 AM   #3
sounds like a kitchen sink strainer basket might need one that is for extra thick bowl here is a link to get you hunting
http://www.elkayusa.com/cps/rde/xchg...nfittings.aspx
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is online now   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
noraman (03-18-2012)
Old 03-18-2012, 06:22 PM   #4
Master Plumber
Javiles's Avatar
http://www.vintagetub.com/asp/tub_drains.asp maybe
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
noraman (03-19-2012)
Tags
drain, faceplate, oversized, tub
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Central Air Secondary Drain Leaking - 3 questions walters_12 HVAC 7 05-11-2011 04:20 PM
Dishwasher drain valve opening WallyWoggle Appliances 1 01-12-2011 09:44 PM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
