Need Detailed Photo Or Diagram - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-28-2008, 10:29 AM   #1
need detailed photo or diagram
have basement bath group preped when house was built, going to complete now. tub, toilet, sink all stubbed under floor to grinder crock. need diagram for grinder pump. plumber left a 2" vent pipe stubbed down through upstairs floor, how do I plumb from pump up to drain line and attach vent? also need photo or diagram for sink, have 1.5" vent stubbed through upstairs floor, leading to basement and 1.5" drain coming up through concrete floor . thanks
butlersprints is offline   Reply With Quote
Old 11-28-2008, 05:35 PM   #2
Anyone ? come on just a little help needed here. thanks
Old 11-28-2008, 09:37 PM   #3
Registered User
Termite's Avatar
There are so many ways that this could be configured it would be futile for us to try to describe it without more information. I'd suggest that you post pictures of the setup that you currently have...Specifically where your drain exits the house to the sewer, and also the ejector pump. With that, I bet we can get it figured out.
I'd also suggest looking at the ejector/grinder pump's manufacturer's website. Many have schematics that will make your life a lot easier.
Old 11-28-2008, 10:05 PM   #4
I don't have the pump yet, my drain exits the home right in front of the grinder crock, approx 6 ' off of floor height, vent is stubbed through upper floor a couple of inches down into basement. I understand basics of plumbing, however I can't seem to picture pumping solids up to drain and tying vent into it with out **** going into vent, so I need pic or explanation. Thanks
Old 11-30-2008, 07:31 PM   #5
Question
1st try
will watch to see what you are told. and you know more than we do.
would like 3/4 bathroom in our basement.have room, have hopes.
jan2009 is offline   Reply With Quote
Old 11-30-2008, 07:37 PM   #6
Registered User
Termite's Avatar
Here's a link to Grundfos' installation diagram. It might help you make some sense of how they vent.
Basically, the pump kicks on at a certain level, and the vent allows the solids/liquids to be displaced.
http://www.us.grundfos.com/web/downl...e/Seeje-io.pdf
Old 11-30-2008, 07:44 PM   #7
i am writing notes to put with what i can find out. thanks.
Old 11-30-2008, 07:55 PM   #8
thats exactly what I needed ,a pic showing what I need to do, thanks
Old 11-30-2008, 08:00 PM   #9
got print of info grundfos thanks
Old 11-30-2008, 08:31 PM   #10
Just passing along, in my local area, its required to have two pumps when installing pump grinders, of course I don't know whats required for your area.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
wiring diagram question screenporch21 Electrical 10 11-30-2008 08:14 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Does this wiring diagram work? beezlebub03 Electrical 7 05-04-2008 11:54 PM
Wiring diagram for this basement eternalmma Electrical 9 03-31-2008 06:39 PM
