Old 08-03-2011, 03:02 PM   #1
Chief Pixel Pusher
Need advise on "DIY" PCV Pipe project
I am making a Camera "dolly" and using 3/4 PVC pipe. I have used 3/4 slip stops for the wheel mounts; but it isn't a real sturdy connection, and very difficult to screw in the bolts (5/16 20) (See images below) anyone have ideas that may give me a better way of connecting the wheels with same size bolts? I'm wondering if I just need a smaller pair of plyers. What about metal connectors? Are there connectors that screw into PCV pipes? Kinda of a plumbing novice, I work on things as they break! Love using the pipe for other projects though!
https://picasaweb.google.com/stembri...99408552941874
https://picasaweb.google.com/stembri...99622534439074
https://picasaweb.google.com/stembri...99739026287266
https://picasaweb.google.com/stembri...99846130812258
javapop is offline   Reply With Quote
Old 08-03-2011, 03:07 PM   #2
Chief Pixel Pusher
The pictures linked didn't attach, here they are again
Old 08-03-2011, 09:43 PM   #3
call me E
TheEplumber's Avatar
Instead of short bolts, why not use a piece of allthread that goes from wheel to wheel as an axle does
Old 08-03-2011, 10:04 PM   #4
Chief Pixel Pusher
Hmm, not a bad idea. I guess I would have to cut it myself, and ensure a clean cut. I may give that a try.
Thank you!
Tags
camera dolly, diy project, pcv, pcv connector
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Leaking drain pipe under kitchen sink dethun Plumbing 20 09-26-2012 08:30 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 12:15 PM
