Need Advice On When To Replace Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2012, 08:05 AM   #16
Rewards Points: 1,214
Leave the copper alone unless the house is on well water then consider replacement.
COLDIRON is offline   Reply With Quote
Old 01-14-2012, 07:52 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 802
Originally Posted by oh'mike View Post
Cut a hot water line and inspect it----In some parts of the world that pipe will be perfectly fine--
If it shows signs of clogging or deterioration--rip it out.
It all depends on the condition. Check it---
I think that is the best advice.
I would look at two spots....one that sees high flow and another that sees little use.
Item of note....I learned something from a plumber once....he said that a majority of pin hole leaks he found were at sweated connections...and a common issue was the inside pipe was not debured.
When I replaced the POS globe valve on the input line of my house, I noticed what looked like a lot of wear around the joint...and it had rough edges. I installed a ball valve....and talk about a difference in noise. Before, you could tell if any water was running in the back yard by the noise in the kitchen. Now, we don't hear anything.
Debur all those connections.
The Following User Says Thank You to ddawg16 For This Useful Post:
plummen (01-15-2012)
Old 01-26-2012, 06:42 PM   #18
Rewards Points: 121
Thanks to everyone for their advice - 3 different bids by 3 different plumbers (plumbing companies) - and the only thing they all agreed on was to replace ALL of the copper. Once the walls and floors were opened up, the copper had already been spliced at alot of different places. There were also pvc drain pipes installed in other areas,quite a few places that had been leaking (past or present) and on and on. The upside is that I have "hundreds" of feet of copper pipe in all sizes, as well as all brass fittings! I'm hoping that I can cover the cost of the job by selling the copper!
JamesRW is offline   Reply With Quote
The Following 2 Users Say Thank You to JamesRW For This Useful Post:
ben's plumbing (01-26-2012), TheEplumber (01-26-2012)
Old 01-26-2012, 08:29 PM   #19
Plumber
TheEplumber's Avatar
Rewards Points: 348
You'll be surprised at how much money you get. Thanks for the update
Old 01-27-2012, 04:15 PM   #20
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Make sure you separate the types of metals. Remove as much contamination as possible, it will increase money you get for copper and brass. Mapp gas torch from any big box and a good set if wrenches.
Sent from my Samsung Vibrant using Android DIY Chatroom
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 01:37 PM
Copper line for refrigerator being used as a ground... seannymurrs Plumbing 2 02-08-2011 10:11 AM
Need advice on tapping into house main Reddhead Plumbing 22 08-21-2010 08:51 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
