Need Advice On Shower Handle Stem - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2014, 10:23 AM   #1
Need advice on shower handle stem
The tip of the plastic stem broke off the other handle (picture is of opposite side), is there a way to take the metal housing off to get the stem off with out calling a plumber and breaking the tile?
If it is fairly easy I would like to fix it myself.
Thanks for any feedback.
Need advice on shower handle stem-2014-03-19-19.04.51.jpg   Need advice on shower handle stem-2014-03-19-19.04.54.jpg
Last edited by mom2girls&boy; 04-10-2014 at 10:26 AM. Reason: wrong picture uploaded
mom2girls&boy is offline   Reply With Quote
Old 04-10-2014, 11:28 AM   #2
Rewards Points: 282
It should be a fairly easy fix, if you can figure out how to get it removed so you can replace it with a new one.
I'm not sure, but it may just unscrew right at the end where the plastic piece broke off or the whole stainless steel piece unscrews from the base. Idk. Have to experiment a little, kind of hard to tell by the picture.
Shut off water. Use 2 channel lock pliers with rag to protect ss, one to hold long ss piece and one for end piece. If you are able to get it free, take it with you to a hardware store and have them match it up.
Sorry I couldn't be of more help to you. Please wait for the plumbers to respond with more advice and suggestions. Thanks.
jmon is online now   Reply With Quote
Old 04-10-2014, 11:33 AM   #3
Rewards Points: 13,712
Water needs to be shut off to the whole house first.
Open the valve to lower the water pressure.
That chrome tube unscrews, then the cartridge can be removed.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jmon (04-10-2014), oh'mike (04-10-2014)
Old 04-10-2014, 04:13 PM   #4
Rewards Points: 582
that is a delta faucet stem extenison ...most hardware stores will have it...
The Following User Says Thank You to ben's plumbing For This Useful Post:
TheEplumber (04-10-2014)
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 05:27 PM
stripped shower valve stem. smaleckar Plumbing 7 12-17-2013 05:02 PM
Shower Stem troubles - Putty v. Tape? brendilon Plumbing 6 10-15-2013 08:08 PM
Ceramic shower stem drop in replacement TexasPenguin Plumbing 0 10-09-2012 10:29 AM
Stuck shower valve stem janecorn Plumbing 0 02-28-2012 09:46 AM
