Need Advice On Rusted Pipe Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2012, 04:32 PM   #16
Thanks for the quick reply, Joe. Out of curiousity, what tool/saw would you've suggested?
So, if the pipe breaks off, there are ways to fix it/get it out?
silencer is offline   Reply With Quote
Old 12-02-2012, 08:59 AM   #17
Hi guys.
Update: Well, after almost a week of trying different tools (wrenches, etc) and using muscles I am still unable to unscrew the galvanized steel pipe that's rusted to the cast iron drain.
I was told by a friend that one way I could try to remove the pipe now (as a last resort) was to saw it off as close to the drain as I could and then use the metal blade on the saw to cut the remaining piece with the threads inside the pipe.
He said to stick the saw gently into the drainpipe where the threads are and cut at positions 12, 3, 6 and 9 (on a clock) and then try and scrape or remove the last pieces of steel pipe.
Is this a "valid" way to finally get the pipe out, or is there anything else I could try? I'm in desperate need of ideas. THANKS!
how to repair bottom of rusted out 10" steel pipe. michael laffert Plumbing 2 04-26-2012 09:19 PM
Replacing Old Rusted Galvanized Pipe Under Foundation JLW2099 Plumbing 7 04-02-2012 02:15 AM
Still have occasional air flow problem from w/heater pipe Landen HVAC 10 02-26-2011 01:58 AM
Condensation in Gas Furnace Vent Pipe chanco HVAC 2 01-08-2011 04:01 PM
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 09:08 PM
