Old 02-14-2010, 08:28 PM   #1
Angry
(Need Advice) Remove 1/2" galvanized NPT pipe from END
I had a plumber fired from a job after several problems (including not p-testing prior to completion of finished wall, forgetting to solvent weld FOUR CPVC joints inside wall, leaking drain line, HOT WATER supply to toilet...).
After correcting all of those (at significant expense), I just discovered newest problem that he used nipples 1/2" too short for the flush mount Kohler body sprays. Although the instructions were quite clear, he failed to account for the thickness of the finished with with tile. The wall is now complete and body sprays won't attach due to the too-short nipples.
I need to remove the nipples from the copper els and replace with longer nipples. However, I'm working through a 4" square hole in the tile between studs and can't get my 10" pipe wrench to turn. Does anyone have advice for removing and replacing these from the end of the pipe?
Hopefully someone can help here or I'll be breaking out tile and backer board.
Cheers.
(Need Advice) Remove 1/2" galvanized NPT pipe from END-img_1213.jpg
VillageIdiot is offline   Reply With Quote
Old 02-14-2010, 08:41 PM   #2
Can't you just grab them with some channel locks or vice grips and screw them out?
bob22 is offline   Reply With Quote
Old 02-14-2010, 08:53 PM   #3
I tried clamping vice grips around the pipe and turning the vice grips with my pipe wrench outside the wall. It wouldn't budge.
Old 02-14-2010, 09:59 PM   #4
two things...first I hope they are brass nipples and not galvanized..
second - try this internal pipe wrench from Superior Tool.
mazzonetv is offline   Reply With Quote
Old 02-14-2010, 10:04 PM   #5
That looks very promising. I'll give it a shot. Thank you!
He did use galvanized. I have brass to replace it. If you want something done right.....
Old 02-15-2010, 07:31 AM   #6
That wrench looks really Kool that should work.
I would tape up some cardboard or something in case I banged the tiles.
SULTINI is offline   Reply With Quote
Tags
bad plumbers, pipe, plumbing
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
Advice needed - Use ABS or PVC for waste pipe under our basemenst slab? drh Plumbing 4 02-03-2008 07:27 AM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Basement Rough In Advice Needed mikemille Plumbing 5 02-18-2007 10:55 AM
