NEED ADVICE: Mystery Water Near Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-20-2013, 04:17 PM   #1
Rewards Points: 334
Question
NEED ADVICE: Mystery water near sewer line
Background:
- New (county connected) sewer line 6 years ago professionally installed
- Replaced old septic tank/field (tank was professionally drained/filled in)
- A few weeks ago the wife noticed sewer smell in back yard
- Spotted puddles of water in one defined area right above new sewer line that showed up only when doing a load of laundry.
Natural deduction would lead me to believe that the sewer line was somehow leaking. So we dug down to the new line (and all around) and we found no leaks from the line. But what we did see was water puddling up from BELOW the sewer line (even though no appliance is running).
So I am now at a loss about where this water could be coming from. The only other idea I had was run off from the old septic field.
Any ideas are appreciated.
tripower is offline   Reply With Quote
Old 10-20-2013, 04:27 PM   #2
Rewards Points: 13,300
Could be a bunch of things.
Distribution box cover collapsed.
Failed leach lines.
Septic tank needs to be pumped out. (most likely cause)
Roots in the leach lines.
Old 10-20-2013, 05:01 PM   #3
Rewards Points: 334
Failed leach lines.
Did you not read the part where I said the septic tank had been drained and filled and is no longer in use in favor of a new county connected sewer line?
Old 10-20-2013, 05:02 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Is your new sewer connection a new septic system or a city sewer?
You answered my question while I was typing.
Coastal South Carolina
Old 10-20-2013, 05:06 PM   #5
A "Handy Husband"
rjniles's Avatar
Leak is in the line upslope from where you see water. You may need a sewer camera to find it. Probablg a broken line to give you that much water.
Old 10-20-2013, 05:13 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 452
Or- some older homes in my area drain the laundry to a dry well- not the septic tank. Perhaps the laundry was not tied into the sewer and the dry well has failed
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
oh'mike (10-21-2013), plummen (10-20-2013)
Old 10-20-2013, 08:04 PM   #7
joed's Avatar
Rewards Points: 12,028
My thoughts as well. The laundry did not tied into the sewer.
Old 10-21-2013, 04:00 PM   #8
Master Plumber
Benplumbing's Avatar
With the hole (you dug) open did you try running your laundry to see if it bubbles up?? Or running any other fixtures?? process of elimination.
Benplumbing is offline   Reply With Quote
The Following User Says Thank You to Benplumbing For This Useful Post:
plummen (10-21-2013)
Old 10-21-2013, 11:14 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 990
find the clean outs and check the flow you might developing a stoppage and the line may be leaking at some point, or one of many scenarios mentioned here... call a plumber
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 10-22-2013, 12:31 PM   #10
Rewards Points: 1,294
This is where my money is...Check all of the interior plumbing and see if it all ties into the new sewer line. You may find a line running out of the house in a different location.
danpik is online now   Reply With Quote
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 01:18 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 11:38 PM
Water in patio gas grill buried gas line. J. Rogers Plumbing 1 08-01-2012 11:52 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
