Need Advice For Installing A Second Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 05:15 PM   #1
Need advice for installing a second shower head
Hello. This is my first post here on the forums. My wife and I just bought a house and I have a question about the shower in our master bathroom. The previous owners completely renovated the master bath and made kind of a strange choice IMO, to only include an overhead waterfall shower head. I think it's cool and nice to have, but not for everyday use.
We've become accustomed to having an actual front facing shower head that's detachable. My question is whether or not its possible to install a second front facing shower head to use in conjunction with the overhead shower. I've attached a couple pictures showing our shower. Is it possible to have them both on or choose one or the other?? If so, how much would something like this cost to either do myself or pay a professional to do it? Thanks!
JewDaddy is offline   Reply With Quote
Old 03-16-2013, 05:22 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 662
Ayuh,... Anything is Possible if ya throw enough Money at it...
Yer gonna need a Plumber, 'n a Tiler to get it done though...
Call 'round for estimates...
Bondo is online now   Reply With Quote
Old 03-16-2013, 08:52 PM   #3
Lord of Slums
Rewards Points: 1,974
Depenz on the look you want. With enough chrome pipe and bracket you could have it look good. You could try and branch off and install a shower bar. Really depends how much money you want to throw at it. You could tear out the tile and re plumb it.
mj12 is offline   Reply With Quote
Old 03-16-2013, 09:02 PM   #4
Look isn't really a big concern. I'm trying to figure out the cheapest and easiest way to make it happen.
Old 03-16-2013, 09:54 PM   #5
Rewards Points: 1,776
http://www.moen.com/bathroom/shower-...arity&offset=0
http://www.amazon.com/Personal-Showe...ef=pd_sxp_f_pt
yOU WILL NEED BOTH AND NO PLUMBER
Old 03-16-2013, 09:57 PM   #6
Awesome. So two questions. How much is that diverter valve going to run me and how the hell am I supposed to install it??? Lol. Thanks
Old 03-16-2013, 10:04 PM   #7
You unscrew the jungle shower head. You screw on the divertor valve one side goes to your hand held the other to jungle shower you reattach... its 33 bucks
http://www.amazon.com/dp/B001002C28/...SIN=B001002C28 is 300 bucks but high quality
And it all matches your current finish.
Old 03-16-2013, 10:10 PM   #8
Wow. Sounds too easy Thanks so much. One more question. Does the water come out of both now or can I choose which one? The reason I ask is the water pressure already seems to be a little low coming from the Jungle Shower Head. I didn't know by diverting flow to another device if it will kill the pressure even more.
Old 03-16-2013, 11:53 PM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
that one is a two-way, which means one or the other. This one from the same source is 3-way and allows either or both, but as you said, water pressure may be an issue.
http://www.amazon.com/U4929-RB-PK-Un...ref=pd_cp_hi_0
Man of many hats
wrangler is offline   Reply With Quote
Old 03-17-2013, 12:09 AM   #10
You're the man!!! Thanks brotha
Need advice in fixing "contractor's" botched shower floor tile job toocheaptohire Tiling, ceramics, marble 5 10-15-2012 03:31 PM
Broken shower head extension (soldered joint) - please help! Simon96Taco Plumbing 24 07-03-2012 03:05 PM
replacing ceiling mount shower head JoanneW Plumbing 3 05-31-2010 09:19 PM
Low Flow Problem at Shower Head steveo178 Plumbing 4 12-27-2009 01:59 PM
Plumbing in the shower head obeans Plumbing 3 03-11-2009 04:08 PM
