Need Advice On How To Clean A Concrete Laundry Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2013, 01:16 PM   #1
Rav
Rewards Points: 564
Need advice on how to clean a concrete laundry sink
This isn't exactly a plumbing issue but I didn't think any other forum here was more appropriate. We have an old concrete laundry sink from the 1930s (pictures below). We intend to keep it, not replace it. It has decades of soap scum build-up and such. I'd appreciate advice on the best way to clean it up as much as possible (I've tried just a stiff brush and water, but that doesn't do anything). I don't intend to paint it, so I'm not trying to etch it. I don't want to use anything dangerous such as muriatic acid. Would white vinegar be good? Or what about a concrete cleaner (such as used for driveways), although there's no oil or grease on the sink. Thanks for your help. /Rav
Need advice on how to clean a concrete laundry sink-cimg2723.jpg   Need advice on how to clean a concrete laundry sink-cimg2724.jpg
Rav is offline   Reply With Quote
Old 01-01-2013, 01:22 PM   #2
Rewards Points: 13,712
Hate to bust your bubble but it's not worth all the time to try and clean it.
Once it is cleaned it now so pitted it would be impossble to keep clean.
Old 01-01-2013, 03:33 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 676
If it was mine, I'd go with the muratic acid- masons use it or something similar on brick. Could even try TSP.
Old 01-01-2013, 04:37 PM   #4
Rewards Points: 582
if it were mine....I would see how hits it would take with a sledge hammer to get it out of my house...sorry ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (01-01-2013)
Old 01-01-2013, 08:41 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
While I agree with the comments about smashing it, there is something to be said about those old concrete sinks. If it's one of the ones i'm thinking about, the thing is huge, and has two giant basins. If you can clean it well enough to get some other kind of coating to stick to it, it might be worth keeping around. (It probably will never look pretty)
Journeyman Plumber
Old 01-01-2013, 08:47 PM   #6
Missouri Bound's Avatar
Try a concrete cleaner....any good hardware store or big box will have it.
Do you want it your way or the right way?
Old 01-01-2013, 09:52 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
LOL depending on the sledge hammer 20 to 30 hits they are pretty strong. some steel reinforced.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-01-2013, 10:05 PM   #8
Plumber
Rewards Points: 676
I found it best to take them out like a water heater- on a hand truck.
But the OP said he wanted to keep it so I didn't suggest tossing it.....
Old 01-01-2013, 10:36 PM   #9
http://www.homedepot.com/Plumbing-Ut...&storeId=10051
Old 01-01-2013, 10:58 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
http://images.ame4u.com/Animated_Cli...ash_hg_clr.gif
Old 01-01-2013, 11:14 PM   #11
I had one of these in a house I owned some time ago. I used Oven Cleaner to brighten it up.
Bill in NJ is offline   Reply With Quote
Old 01-04-2013, 08:41 AM   #12
Rav
Rewards Points: 564
I wouldn't exactly say it looks pretty now, but I think I was successful at cleaning it up. I used Simple Green Lime Scale Remover, which is relatively mild but did the job along with a Scotch-Brite pad. The drain and plumbing underneath is in decent shape so it was worth it for us to keep this old concrete laundry tub going. If you're interested, on the bottom it says "Maryland Nustone Corp Laundry Tray," and handwritten is "10-13-31." Thanks for all of the responses.
See pics below (view is of the same area both before and after).
Need advice on how to clean a concrete laundry sink-before.jpg   Need advice on how to clean a concrete laundry sink-after.jpg
Old 01-04-2013, 08:51 AM   #13
Roofmaster
Rewards Points: 2,210
Far cry from the HD Plastic shakey legged POS posted, aint it?
I was going to say to sand blast it, then epoxy coat it, as you sound like you are keen to keep it. The problem I saw with these is the Angle Iron Stand rusts out, and the sink is so heavy the stand collapses.
Old 01-04-2013, 09:04 AM   #14
Rav
Rewards Points: 564
Sure is! Despite a small amount of surface rust on our tubs stand, it's in good shape (see pic below).
Old 01-04-2013, 09:22 AM   #15
Doing it myself
Alan's Avatar
I've seen lots of them mounted on cinderblocks, never a stand like that.
Journeyman Plumber
Tags
clean , concrete , laundry , sink
Attach Laundry Sink to Concrete Floor sweaty Building & Construction 2 01-21-2012 07:44 AM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Access behind laundry sink CharlieG Plumbing 6 11-10-2010 01:37 PM
laundry sink needs wall-mount faucet - can I cheat? bluebee1314 Plumbing 2 04-05-2008 11:45 AM
