Near Horizontal To Sewer - Macerator Waste System? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2009, 12:48 AM   #1
Rewards Points: 1,016
Near horizontal to sewer - macerator waste system?
I am thinking of putting a bathroom in my workshop at the back of my property. The problem I forsee is the near horizontal run the sewer line would have to be - there is some drop, probably just a couple feet over the approx 200 that would be the length of the run.
I have been reading on macerator waste systems, which help - but still need the normal gravity drop to the sewer. Is there such a thing as a macerator waste system with a pump to allow the long near horizontal discharge?
I would be installing a toilet, shower, hand wash basin, and a utility sink. the usage and volumes would be low.
All suggestions to my problem are welcomed!
Thx!
Old 09-28-2009, 10:07 PM   #2
Rewards Points: 1,448
I was thinking you would have to put in a vertical zigzag system, with normal slope down to a holding tank in the middle of the run, and the macerator pumping the sewage sharply upwards several feet at that location to the next section of sloped pipe (or maybe two macerators and holding tanks, at the 1/3 and 2/3 marks respectively).
AllanJ is online now   Reply With Quote
Old 09-29-2009, 10:20 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... An inch in 10 feet is sufficient fall,... Sounds like it'll work Just Fine with a 4" hard pipe run...
Bondo is online now   Reply With Quote
Old 09-29-2009, 11:49 AM   #4
Household Handyman
Rewards Points: 1,408
"Is there such a thing as a macerator waste system with a pump to allow the long near horizontal discharge?" Yes. We installed one at a friends "farm" (9 acres) about two years ago. He wanted a room for toilet, shower, hand sink to clean up after working horses. This unit had a 230+ foot run of 2" pipe back to his septic tank, per the instructions from the local plumbing suppy house he bought it from. It has worked fine since installation. Part of this piping was actually uphill, but the plans from the maker of the system stated that this would work within certain parameters. IMO-Bondo is correct also, 1"/10ft. should work for your system. Sewer lines are not usually set up so the waste runs through very fast. Some settling and waste degradation takes place within these pipes. Good Luck, David
Redoing our sewer system maryr006 Plumbing 3 08-16-2009 04:43 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
horizontal loop system for under ground heat exchange jerry b Building & Construction 1 01-22-2008 08:04 AM
