Natural Gas Shut Off Locks - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2010, 10:05 AM   #1
I'm having a gas line installed to an outdoor grill. There will be a shutoff on the line at the grill. I'm concerned that a kid or vandal might open the gas when I'm away. Is anyone familiar with types of locks that can be placed on the shut off to prevent easy access to the gas for intruders? Are there sites that display lock types?
notalent is offline   Reply With Quote
Old 05-20-2010, 11:14 AM   #2
There are a couple options you can do.
1. You can put a 2nd valve inside the house before it goes outside
2. You can get a valve with a locking wing which is a valve with two "wings" on it that have two holes so when the valve is closed the holes line up so you can put a small padlock through the holes. something like model GC275 at this link:
http://www.tristatemeter.com/plug_valves.htm
3. You can get a specialty valve already with a lock and key, something like this:
http://www.gasproducts.co.uk/acatalo...alve_1_2_.html
4. You can use a ball valve and unscrew the handle after each time you use it.
The Engineer is offline   Reply With Quote
Old 05-21-2010, 08:17 AM   #3
Thanks Engineer; very useful info.
Old 05-21-2010, 01:40 PM   #4
Household Handyman
Rewards Points: 1,408
You don't mention the type of valve you will be using. There are various types of locking devices out there for many different types of valves used on gas lines. I have, leftover from retiring, devices made for placing on ball valves approved for gas use. These just slip onto the valve, over the handle, and accomidate a padlock. Cost efficient and effective, such as McMaster-Carr item #45075K37. These can also be purchased from local safety materials suppliers. David[IMG]file:///C:/DOCUME%7E1/DAVIDC%7E1/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Old 05-21-2010, 05:21 PM   #5
If you use a quick-disconnect, the flow will automatically stop when the hose is disconnected. Of course, anyone with a wrench could take it off, but that of course could occur also with the other solutions above.
I have such a disconnect on my grill.
RoyalAcresRod is offline   Reply With Quote
Flexible Natural Gas pipe/Line andy5111 Plumbing 10 09-25-2009 11:41 PM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Replacing mortise locks? chins01 Remodeling 6 07-16-2008 08:14 PM
