Natural Gas Pipe Sizing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2010, 09:00 PM   #1
Natural gas pipe sizing question
Hi guys, I've looked but can't seem to find the right answer. I messured my supply line to my house and it appeares to be about 1 1/8" OD on a tape messure. I don't have a caliper handy. I'm guessing this is a 3/4 line but is that normal for a house supply?
Currently the only gas appliances are a furnace and water heater. I am looking at running a gas dryer and eventually would like to add a gas range and outside outlet for a bbq, maybe patio heater in the future.
Currently the water heater and furnace are about 25' from the supply on the side of the house. The dryer would be about 3-4 feet from these, through a wall. From the dryer it would be another 10 feet to the eventual location for a range and then another 10-20' for the eventual ending location for the bbq and patio heater.
If this is in fact a 3/4 line is adding a dryer possible? What about a range and bbq?
Thanks for your help.
Mark
moosebrew is offline   Reply With Quote
Old 12-18-2010, 09:12 PM   #2
Experienced
Jackofall1's Avatar
http://www.engineeringtoolbox.com/na...ing-d_826.html
That is a 1" line and should be fine to run your needs today and in the future, assuming that is the pressure is there.
Old 12-18-2010, 09:17 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
my house is supplied with a 3/4" line and I run everything gas. furnace, range, water heater, dryer, even a garage heater, no problems.
hardwareman is offline   Reply With Quote
Old 12-18-2010, 09:20 PM   #4
wow, thanks for the super fast responses! I appreciate the link and the help.
Mark
Old 12-18-2010, 09:49 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 818
Not another gas thread! Round 2
Old 12-18-2010, 10:35 PM   #6
Licensed Master Plumber
The correct answer is.......42
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
HVAC Sizing Question hawks000 HVAC 2 11-04-2010 08:05 PM
Header sizing question..... Oxymoron Building & Construction 2 01-08-2010 09:13 PM
How close can a potlight be to natural gas pipe? DrmChld Electrical 4 09-21-2009 04:55 PM
natural gas pipe line dave444 Plumbing 7 08-01-2009 09:54 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
