Old 06-13-2009, 02:50 PM   #1
Question
Natural gas line?????
About three years ago, I had a contractor install 1-1/4" polyethylene gas line for my outdoor fireplace and two fire bowls. I was unable to complete the project at that time for many reasons, but I am starting back to work on it now. I have a few questions about the gas line:
Some of the stubs with key valves attached need to move a few inches For example, I need to move the key valve one cell over to the right in the attached image. What is the best way to do this without unscrewing/loosening the pipes from the risers in the ground?
Is it bad to have couplings and elbows in the block for reasons such as leaks, etc.? I will need to use couplings and elbows to move the key valves. Any other ideas?
When I run gas pipe from the key value to the inside of the fireplace hearth, do I use the green PVC coated gas pipe or flexible gas line?
Is it common to encase the gas line in block? What if one needs to access it later for service?
I would also like to pressure test the gas line before I surround it with block. Does 50 - 60 PSI for 15 minutes sound correct for pressure testing the polyethylene gas line? I can't remember what the contractor test it at for the inspection.
By the way, I live in Surprise, Arizona.
figs is offline   Reply With Quote
Old 06-14-2009, 02:13 PM   #2
when it comes to gas CALL A PRO!!!!
al's sewer is offline   Reply With Quote
More On This Topic
The next thing we are going to do is turn off the gas supply to the stove. There usually is, this is like, I think, a 1/2" or 3/8" gas line, you might want to just replace this. This is a new one. So anyway, you would generally have a gas valve that... Read More »
Many outdoor fireplaces are fancier than indoor ones. Some expensive fireplaces stand over eight feet tall and include MP3 docks. Less fancy ones are just a metal bowl with legs. Almost anyone can afford an outdoor fireplace because there are many styles... Read More »
Gas Stove Piping
Gas Stove Piping by Expert Village
Okay, now you can see, this is a standard gas supply; it's in a black steel pipe. Now you should always use black pipe for gas. This is a black pipe fitting here, and this is black pipe fitting, and this is brass. You should not use galvanized, you can... Read More »
I'm Fernando we are here with Expert Village and we are going over setting the control for your timer. Now with your timer each timer is individual and it comes with actual instructions if you are not familiar with how to operate this timer we ask that... Read More »
The average gas fitter has to do more during the average day than simply align gas pipes underground. Gas fitters need to understand the entire gas usage process from production through metering and distribution in residential areas. You need to become... Read More »
Grounding on Natural Gas Line HobieCat Electrical 10 06-09-2009 11:59 PM
PVC line on natural gas line for BBQ Nikroo Plumbing 28 05-13-2009 10:01 AM
Natural gas line to garage SxS Plumbing 13 02-21-2009 08:30 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 08:53 AM
Demo of Natural Gas Line millipede Safety 3 11-13-2006 02:13 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
