Natural Gas Ball Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2014, 08:32 PM   #1
When installing a ball valve on a residential natural gas line, is there any difference between those common NG red ball valves like this one:
Or a standard "250 or 600 WOG" valve like this one:
Is there some kind of code that dictates that the red valve must be used?
PaulBob is offline   Reply With Quote
Old 07-30-2014, 08:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 664
WOG = water, oil, gas
I have used the ball valves on gas multiple commercial jobs.
I can't quot a code reference though
Old 07-30-2014, 09:07 PM   #3
Yes, me too.. I have no doubt they will function properly but I wasn't sure if there was some residential specific code about them.. You never know when there's some obscure code snippet like "No valve shall have a handle longer than your little finger" or something.
I know they're fine up to at least 5 PSI gas because I've installed them before at those pressures on a 5000 sqft oven.
Old 07-31-2014, 02:29 AM   #4
Rewards Points: 6,652
I like the Red Handled one, due to it does not stick out if attached to the gas line behind a stove, next to a furnace or water heater. The second one is good for a shut off for a gas fired fireplace. Gives you something that you can push with your hand, or pull on it, vs. trying to turn it with limited space.
Old 07-31-2014, 05:46 AM   #5
MarginallyQualified
Rewards Points: 2,464
I recently installed a 1" WOG ball valve because I couldn't find a gas valve that size.
At the more common 1/2" and 3/4" pipe sizes... use the one expected to be seen.
Old 07-31-2014, 06:29 AM   #6
Rewards Points: 1,234
All kidding aside, those long handles can be a safety factor when clothing unknowingly gets caught and turns the valve on. You don't want to hear the rest of the story "Paul" it wasn't all that funny. although my co-worker thought so at the time.
Easiest way to go from 1/2" ball valve to 1/4 inch compression fitting? Studly Plumbing 11 11-03-2011 07:57 AM
Natural gas valve JKT HVAC 1 10-02-2011 05:01 AM
need help finding a selenoid actuated ball valve to control "circulation line on HWH tominator Plumbing 1 03-29-2011 09:46 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 08:23 PM
