Narrow Profile Ball Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2011, 09:21 AM   #1
Rewards Points: 248
narrow profile ball valve?
I'm trying to put a shutoff valve behind a decorative panel-rad and don't have enough space because of how far the supply/return pipes extend.
Is there such a thing as a threaded narrow-profile 1/2" ball valve, where the handle doesn't extend so far out from the fitting, as in the attached diagram?
I could offset the copper line with a 45-degree elbow, or bend a handle flat, but maybe this "slim-line handle" version exists?
diy888 is offline   Reply With Quote
Old 04-02-2011, 09:31 AM   #2
Rewards Points: 352
take the handle off and leave it tied to the pipe with string so you don't loose it.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
the_man (04-02-2011)
Old 04-02-2011, 09:55 AM   #3
Rewards Points: 248
But I need to be able to use the valve handle to shut the flow off. So the handle can't have that offset bend, because there's not enough room.
Old 04-02-2011, 10:00 AM   #4
fabrk8r
fabrk8r's Avatar
Take the handle off, flatten it with a brake (or hammer and dolly bar) to remove the offset, and reinstall the handle. You could also just use a small adjustable wrench to shut it off when necessary.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-02-2011, 10:08 AM   #5
Experienced
Jackofall1's Avatar
Install the valve 90* to the openning, you will have to leave the cover off when the valve is shut off.
Mark
Old 04-02-2011, 11:24 AM   #6
Household Handyman
Rewards Points: 1,408
There are on the market "low profile" ball valves with "T" type handles which may just work for this. BUT-the only one's I am familiar with are Stainless Steel, which would not be a bad idea anyway. Try a search at "McMaster-Carr".
Old 04-02-2011, 12:01 PM   #7
Rewards Points: 248
Thanks for all the suggestions.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
need help finding a selenoid actuated ball valve to control "circulation line on HWH tominator Plumbing 1 03-29-2011 09:46 PM
looking for an electronic ball valve with timer tominator Plumbing 1 03-24-2011 12:05 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
