Old 04-09-2007, 07:47 PM   #1
name that gross drain thingy in my basement...
Ummm, what is this thing?
It looks like there's some sort of runoff pipe there facing upwards at the top,
it's got some gross looking stuff in it, but no smell. Some sort of drainage? It isn't septic related (as far as i know?) the house is from 1958.
elementx440 is offline   Reply With Quote
Old 04-09-2007, 08:24 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If you run water in that tub, does the water from it flow through this area?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 04-09-2007, 08:40 PM   #3
Eibwen
Looks like a basement floor drain that somebody cemented a piece of terra cotta chimney liner over for some reason. Maybe it was draining slow and the chimney liner was supposed to give it more time to drain when it backed up...
Sammy is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
adding a basement tub drain wibass Plumbing 2 06-09-2007 07:50 AM
Basement Floor Drain amazinlittledevil Plumbing 8 01-04-2007 02:17 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
