Nail In Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-19-2013, 06:20 AM   #1
Nail in Pipe
I am doing a kitchen renovation and have discovered that the original drywallers put a drywall nail (still there) in the 3.5" ABS vertical drain stack. It probably has been there for 25 years! There appears to be no leaking but I want to repair this while it is still open. Any suggestions?
rjf44 is offline   Reply With Quote
Old 07-19-2013, 06:38 AM   #2
Rewards Points: 365
Cut through the pipe where the nail is and install a coupler. I suppose you could also patch the pipe with a piece of ABS glued over the hole but I doubt that is to code.
I'd let someone else chime in besides me.
info2x is offline   Reply With Quote
Old 07-19-2013, 06:39 AM   #3
DIY staff
Rewards Points: 7,174
Simple or fancy?
Simple----buy an ABS repair coupling (that one has no stops in the center)
Cut it in half---clean,prime and glue it over the puncture using ABS solvent.
Fancy---cut the pipe at the hole---separate the pipes enough to slip on a rubber fern co fitting or the repair coupling mentioned above---and use that----
Old 07-19-2013, 09:41 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
I guess you don't want to hear my suggestion......
Since it's just a vent stack....
Pull the nail.
Take a slip coupling like Oh'Mike suggested...cut off a 1/3 of one side....this should give you enough room that with the flex, it will push over the pipe.
Slop on lots of ABS cement....push on the slip coupling and glue in place. I would use a strap to cinch it up tight while it drys....
But that would be me and my hack....I would rather do that than cut the pipe.
Old 07-19-2013, 01:56 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Agree. Use a slip coupling cut in half. Glue it and then strap it in place with hose clamp. Inspect the pipe to be certain it is not cracked though.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (07-19-2013)
Old 07-19-2013, 03:13 PM   #6
Rewards Points: 582
ready for this one......cut some abs pipe gather the shavings mix it up with abs glue to make a paste ...remove nail sand pipe push some into hole.. apply to make a patch.......ben sr
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
MTN REMODEL LLC (07-19-2013), oh'mike (07-19-2013)
Old 07-19-2013, 06:36 PM   #7
Rewards Points: 2,042
How about get a nice new shiny nail and stick it in the hole. Fixing it the correct way doesn't seem to be an option. I seriously doubt cutting the pipe and installing a full coupling would be to hard to accomplish.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
ben's plumbing (07-19-2013)
Old 07-19-2013, 07:22 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 832
We had a thread like this a long time ago-
some said to put a pop rivet in the hole
Old 07-20-2013, 11:11 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
I will confess to this:
3/8" stainless screw with a small rubber washer.
Coastal South Carolina
Old 07-20-2013, 11:12 AM   #10
JOATMON
ddawg16's Avatar
On a vent pipe? Hell yea......
Old 07-20-2013, 11:14 AM   #11
JOATMON
ddawg16's Avatar
I think what is important to point out here.....
Because it is 'just' a vent pipe (single story I'm assuming).....it's not going to have water sitting in it....so just about anything is going to work.
If this was the wet section of a drain? Then a proper repair would be in order.
Old 07-20-2013, 12:21 PM   #12
Rewards Points: 582
ok where did the op say it was a vent stack....my guess if he is in the kitchen ...it is a waste stack???????ben sr..if the bath is above it...
Old 07-20-2013, 01:57 PM   #13
If final air were done like they are supposed to be. All of this shows...
This is a direct result of code officials not doing there job.
Old 07-20-2013, 02:01 PM   #14
JOATMON
ddawg16's Avatar
Good point Ben....for some reason I was thinking vent stack....
A pipe that big means either a second story toilet above or this is the main vent..
Old 07-20-2013, 03:51 PM   #15
Rewards Points: 365
Excuse my ignorance but what is final air? Pressurize the vent system?
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
framing nail went throug PVC pipe amakarevic Plumbing 8 10-06-2008 04:43 PM
