#16 |
Mystery sediment in my kitchen sink
See reply #10 above.
Does the sulphur and iron treatment system flush waste water down the drain every so often, entering at a point near the sink drain? Could there be a partial clog there so when the treatment system cycles, its outflow backs up into the sink because it can't go down the drain fast enough? I would not expect this to be voluminous enough or often enough to overload a septic tank.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 01-12-2013 at 11:11 PM. |
#17 |
I think Alan is the winner. the water conditioning equipment is back washing into the drain at a higher rate than the drain is capable of handling. then it backs up and exits the drain at the first available spot, the kitchen. plug both drains and watch it bubble up at another sink, unless it has enough pipe to hold it.
call back the water conditioning people for an inspection. bernie |
#18 |
To check if backup from the backwashing cycle of the water treatment equipment is causing the problem initiate a manual backwash of the equipment and watch the sink during the cycle. The backwash cycle will probably take 15-20 minutes.
#19 | |
Mystery sediment in my kitchen sinkQuote:
Since I posted this query, on Friday and again on Tuesday at night the water came into the sink. I had filled a zero water pitcher the night before and left it in the sink but the water coming into the sink from the drain turned the pitcher over in the sink. (That's a fairly large pitcher). But why does it only happen at night? |
#20 | |
It seems my mystery sediment is showing up every 3 days. My new water treatment system is in a separate room outside. This morning (after 2 days of mild snow and light rain), the backup from the overflowed double sinks ran over my counter and puddled onto the floor. I know I need to call someone but should I call the people who installed the new water treatment system or the person who installed the new anti-gravity pump? Or maybe just a plumber? Thanks again. |
#21 |
Super Moderator
Your filter installer is not involved with your problem---call the lift pump guy--chances are he's also a plumber---ask his advice---
New members: Adding your location to your profile helps in many ways.--M-- |
#22 |
Hello all:
I had a plumber take a look at the pipe connections. Sure enough, the first thing he suspected was accurate. The water treatment system was piped directly into the kitchen sink to drain. The anti-gravity pump couldn't handle the water dumped into it OR the sink for that matter. So, now the drain lines from the water treatment system will be plumbed to go outside. Now why didn't that occur to me? My previous house had the waste water being pumped outside as well. No need to have the waste water from backwashing going into the septic system. |
#23 | |
The backwash could kill grass or plants or shrubs especially when it drains onto the ground in the same place.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
| The Following User Says Thank You to AllanJ For This Useful Post: | momof2labs (02-01-2013) |
| Tags |
sediment in sink ![]() |
| Display Modes | |
| Resetting Undermount Kitchen Sink | Voss | Plumbing | 0 | 02-24-2012 01:47 PM |
| How bad/unusual is it for a kitchen sink under window to be off-center? | Iron Petunia | Remodeling | 17 | 11-21-2010 07:33 AM |
| Kitchen Sink Moved - new kitchen | sleepysmurf | Plumbing | 1 | 08-10-2010 07:38 AM |
| Moving kitchen sink | teachtech | Plumbing | 4 | 08-08-2010 11:13 PM |
| Need help re-routing kitchen sink vent | Fingers | Plumbing | 11 | 10-23-2009 04:17 PM |
