Mystery Floor Drain Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2008, 10:56 PM   #1
Mystery floor drain removal
I have a floor drain in a shower stall that I can't remove. I can't tell (see pictures) how the drain was attached. scrapeing away the grim around the drain pipe shows something metal, but it's very soft, and not un-screwable. I can't find any gaskets. How do I get this thing out? This is a very old shower stall (sheetmetal) and looks like it was installed as one piece, base and all. I don't think there is access to this part of the crawl space. What are my removal options. I do not plan on putting a shower back in, but I wouldn't mind a floor drain here.
Mystery floor drain removal-img_0811.jpg   Mystery floor drain removal-img_0813.jpg
Advertisement is offline   Reply With Quote
Old 04-03-2008, 02:30 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It could have been leaded in. Did you try taking a torch to it to see if it melts?
Old 04-03-2008, 03:29 PM   #3
Send a message via AIM to Marlin
Looks like a lead joint. See if that gray stuff around the edges is lead. It should scrape very easially with a screw driver or anything sharp and hard. The whole shower pan is probably lead.
If it is lead grab a drill and drill a bunch of big holes in it. You should then be able to dig out the lead and oakum with a screwdriver. You can then either cap the line below the floor or install a floor drain (so long as the pipe has a trap). If you install a drain you will need to periodically add water to the trap to prevent sewer gasess from coming up through it.
Marlin is offline   Reply With Quote
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
Light Switch Mystery csteinke Electrical 10 06-06-2007 01:33 PM
chimney stack removal davedish Building & Construction 9 02-22-2007 08:07 PM
