Mystery Fixture - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 05:33 PM   #1
Mystery Fixture
I have a ten year old kitchen sink with faucet. The tubing that runs from the water inlet to the faucet is leaking from the inside. I want to replace the
tubing but it seems to be some odd design. I took the tubing and faucet to
Lowes, Home Depot, and a Plumbing supply company here in San Antonio and they all tell me I have to get the new faucet and tubing from the company that it came from. Unfortunately there is nothing, anywhere, to say who made this apparatus. The problem is in the connection from the tubing to the water inlet. The tubing end slips over the water inlet and its
held in place by a plastic clip.
Have anyone seen this before. DO you know who made it?
ronniez is offline   Reply With Quote
Old 08-15-2011, 06:11 PM   #2
Rewards Points: 338
usually the indication of make/manufacturer is somewhere on the handle. the set screw cover should have something, or take the handle off and look underneath for any parts that are stamped. that's how i figured out the make and model of my kitchen faucet.
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
ronniez (08-15-2011)
Old 08-15-2011, 07:35 PM   #3
Rewards Points: 1,520
Looks like the clip on my Delta but I guess other companies could use similar technology.
bob22 is offline   Reply With Quote
The Following 2 Users Say Thank You to bob22 For This Useful Post:
plumberinlaw (08-16-2011), ronniez (08-15-2011)
Old 08-15-2011, 08:25 PM   #4
There's no Id anywhere on the sink or faucet. I even tore some of the
cabinet out, to look,and found nothing.
I checked Delta and the connection method is similar but one wouldn't
be able to replace the other.
Thanks for your comments.
Right now I'm going thru the original specs from the builder and all it says about the kitchen sink is It's Option#6 Virkrell White with single lever pull out faucet.
Old 08-15-2011, 08:50 PM   #5
Bob22 you were right it's a Delta. Found it at
http://www.deltafaucet.com/customers...0#viewDocument
Thanks for the tip!!!
Old 08-16-2011, 08:34 AM   #6
Good news. Now on to the next step; fixing it.
Old 08-16-2011, 10:41 AM   #7
Delta
Called Delta this morning and they are going to send new tubing, new
wand, and new on/off lever out to me free. They have life time warrenty
on all of their faucets!!
Old 08-16-2011, 10:43 AM   #8
Life is good when that happens!
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 03:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 12:19 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
