Mystery Bathtub Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2011, 11:14 AM   #1
Mystery bathtub leak
I am a newbie to this type of site so have patience with me. My house is on a slab, and built in the 50's. Since I moved in, the bathtub drain has always been slow. It seems to be getting progressively worse as time goes by. On at least two occasions I have had water leak out between where the walls and the bathtub meet out onto the floor and even under the tiles. This only seems to happen when I vigorously plunge the bathtub drain trying to get the water to go down. Does this give a clue to anyone about where a leak might be, as I am clueless. Thank you.
wderain is offline   Reply With Quote
Old 01-14-2011, 11:49 AM   #2
Rewards Points: 352
Take off the inspection panel and have somebody watch next time you plunge the tub, that will tell you what you have to repair.
plumberinlaw is offline   Reply With Quote
Old 01-14-2011, 02:39 PM   #3
DIY staff
Rewards Points: 7,174
That's some old plumbing--in those days all the fitting were metal of some kind--by now anything could be rotten.
Like Plumberinlaw suggested--open up an inspection port so you can see under the tub at the drain end,
If the tub is 'trapped' by walls that can't be opened--the tub may need to come out to repair.
Post pictures--Mike--
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 10:40 PM
Bathtub leak DebraC Plumbing 1 07-07-2010 11:39 AM
Mystery leak!!! Chuckwagon Plumbing 3 01-15-2010 06:28 PM
Bathtub faucet leak in wall seabreezz Plumbing 3 02-14-2009 11:59 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
