-   -   Mysterious Slab leak (http://www.diychatroom.com/f7/mysterious-slab-leak-164230/)
Seema 11-20-2012 07:32 PM
Hi, we recently had a catastrophic slab leak. Our kitchen, dining and family rm had to be demo'd so that the restoration co could remove the water and dry it. All our hard wood has been removed too, extensive damage to our floor, cabinets and island. The 1 st day the plumber thought it was a pin hole leak, but as he did not have the equip to proceed further, he said he will come later. Since then 6 plumbers have come and they are unable to identify any leak, some say it could have sealed with something. The restoration co was sure it was a slab leak from the pressured copper pipes as gallons of water was removed and dried over 2 weeks. So my question is- how can we detect the leak and proceed to repair it? Please help
eclark 11-20-2012 08:54 PM
Put a cap on the end of the supply lines, turn the water on and watch for where the slab starts to get wet.
TheEplumber 11-20-2012 09:23 PM
199 Attachment(s)
Be sure no water is running from any faucets in the house. Go out to your water meter and see if the dial is moving. If so- you got a leak. To help pinpoint it hire a leak locating service. Their equipment can hear it through the floor
gregzoll 11-20-2012 09:37 PM
I do not understand how one little leak can cause you to gut the whole house. Sounds more like a leak above slab that caused it. Without pictures of before & during, no way to tell. As for determining if there is a leak, they will have to pressurize the lines and place a gage on them, to see what happens.
joecaption 11-20-2012 10:08 PM
It was common years ago on slab houses to just run the pipes right through the slabs. I've seen both copper and steel lines done this way.
At some point there all going to fail and leak.
Even Frank Loyd Wright designed homes done this way have all since been replumbed.
Does sound odd to have that much water all of a sudden. More often there's a pin hole leak and the floor just has a damp spot that needs to be wiped up/
Sounds more like the relief valve on the water heater blew and once the pressure when down it reseated.
One good reason the heater needs to be sitting in a pan with a drain on it to the outside or to a floor drain.
