My Well Pump Is Running But No Water In House - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2013, 10:46 AM   #1
my well pump is running but no water in house
Need help!!!
Last night my water went off in my house. I have a less than 2 year old well thts a `140deep in 4 streams of good water, last 2 being shell. My pump was running and shows 60n pounds of pressure.
Pissdoffcheroke is offline   Reply With Quote
Old 09-07-2013, 11:20 AM   #2
Originally Posted by Pissdoffcheroke View Post
Need help!!!
1. Is your pump above ground or in the well?
2. If above ground, have you checked to see if it has prime?
3. Have to do a little more troubleshooting to see where the problem is.
jmon is online now   Reply With Quote
Old 09-07-2013, 01:50 PM   #3
Rewards Points: 1,858
Turn your pump off before you burn it out. You most likely have a deep well pump. The foot valve may have gone bad. I would suggest you call your well guy.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
jmon (09-07-2013), oh'mike (09-07-2013)
water level equalizing in sump pump basin? dmp Plumbing 21 04-13-2012 06:42 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Pump house location lleveen Plumbing 0 08-26-2011 08:42 PM
No water in house dls6w4 Plumbing 10 02-12-2011 06:45 AM
Running water sound in the wall? cpourfarid Introductions 2 09-26-2010 09:13 PM
