My Water Tank Won't Fill Up. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2011, 11:45 PM   #1
My water tank won't fill up.
My toilet water tank won't fill up with water. I turned the water valve off. But when I turn it on it goes directly to the bowl then out the pipes. The bowl never over flows, but it's like someone is CONSTANTLY flushing. I have no idea what is wrong with it. Please help!
Tabatha295 is offline   Reply With Quote
Old 10-15-2011, 11:48 PM   #2
It's the flapper
SuperPlumberGuy is offline   Reply With Quote
Old 10-15-2011, 11:48 PM   #3
Rewards Points: 1,418
Have you checked the flapper in the toilet tank for proper sealing? (on older toilets that part is a ball or large plug that goes over the opening at the bottom of the tank and is also lifted by the flush lever)
If the flapper has become stiff or warped with age that could also prevent proper sealing.
The Following User Says Thank You to AllanJ For This Useful Post:
Tabatha295 (10-15-2011)
Old 10-15-2011, 11:49 PM   #4
We tried finding a flapper that would work for the toilet but cannot. To me it seems like a weird flapper, but I don't know much about toilets.
Old 10-15-2011, 11:51 PM   #5
It doesn't have a plug like older toilets(the ones with a flush chain). It's like a long plastic thing that get's pulled up when flushed.
Old 10-15-2011, 11:56 PM   #6
Oh, you know. The seal on the flapper does seem a little old. We also tried finding the right rubber seal but can not.
Old 10-16-2011, 12:20 AM   #7
Missouri Bound's Avatar
Find a plumbing supply house. Can you remove the "long plastic thing" and take it to them? If they can't get it or tell you who can, it's time to replace the toilet.
Old 10-16-2011, 12:25 AM   #8
jules4's Avatar
It sounds like a Mansfield - does the flush valve look like either of these:
If so, you probably need to replace the red washer (part M001 in the diagram), or possibly the entire flush valve (make sure you get the right model valve for your toilet: 210 or 211) - you can get both at home depot.
Email: the to-do list anyone in the world can add items too.
jules4 is offline   Reply With Quote
The Following User Says Thank You to jules4 For This Useful Post:
Tabatha295 (10-16-2011)
Old 10-16-2011, 12:32 AM   #9
Oh my gosh. You saved my life. Yes, it is model number 211. Thank you sooo much.
Old 10-16-2011, 01:03 AM   #10
jules4's Avatar
Awesome - glad I could help. You'll be glad to know the washer is super easy to replace.
And you actually owe your life to my grandmother - just had to fix one of these for her
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
hot water tank help needed psp Plumbing 2 08-22-2010 03:46 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Water tank problems chapmanm02 Plumbing 5 04-29-2009 08:11 AM
