Is My Water Heater Large Enough? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2009, 07:58 PM   #1
Is my water heater large enough?
Hi everyone.
My apartment has a 50 gallon electric water heater. Both the top and bottom burners are set to the "middle" position on the thermostat, which I think is just called "hot." There is barely, but not quite, enough hot water for two 10-15 minute back to back showers. Does that sound right? I thought that a 50 gallon tank would be plenty for just two people. Any thoughts?
To be exact, my heater is the M-2-50T6DS from Bradford-White -- specs are here
Thanks,
Michael
Chicago, IL
logan is offline   Reply With Quote
Old 02-03-2009, 08:19 PM   #2
Safe, Most of the Time!!
brokenknee's Avatar
Sounds to me one of the heating elements is burnt out.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 02-03-2009, 08:48 PM   #3
Remodeling Contractor
When was it last flushed? It should be plenty of water for two normal showers. But are you using multiple heads and two hour showers. If the unit is flushed be sure the sediment was actually removed. Many times the flakes are too big to get through the valve You may need to remove the bottom element and spoon out the calcium buildup. But you need to check both elements first. You can get a cheap water heater tester at Home Depot or Lowes and the directions for testing are on the package.
Old 02-03-2009, 09:24 PM   #4
brokenknee's Avatar
Can also check it with an ohm meter. Make SURE the power is off, disconnect one of the leads to the element, check for continuity, repeat for other element. If you have continuity the elements are most likely good, if not they are bad. If the water heater is over ten years old and the elements are bad I would replace it.
Old 02-03-2009, 09:40 PM   #5
Res Ipsa Loquitur
You said apartment- that you rent? If so then you don't "own" the heater. Talk to the building super or owner about getting a replacement since it is not up to your needs.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-03-2009, 09:47 PM   #6
brokenknee's Avatar
Yep, could not agree more. I need to slow down when I read these post as sometimes I have a tendency to miss these important little details.
Old 02-04-2009, 07:25 AM   #7
Sorry, I should have said "condo" instead of "apartment." Yes, I own the heater. It is only 6 months old. I have opened the drain valve recently and there doesn't appear to be any sediment, as you'd except from a new unit. I suppose it's possible one of the heating elements is bad. We don't have a fancy shower...just a single shower head, probably low flow.
Old 02-04-2009, 07:58 AM   #8
the Musigician
DangerMouse's Avatar
hmmmm, when i put in our brand new 50 elec., i thought it'd have enough for my daughter's long (20, 30 min.) showers, but it still wasn't quite enough. though it heats up in 10 or 15 minutes. so i'd say with yours, it's probably ok. i could be wrong, i sometimes am, but i don't think you have a problem with the heater. take shorter showers or go to an 80 gallon tank?
water flow is what? around 2 gal. a minute in a normal shower?
Nestor Kelabay (very informed guy) or someone else here can give you that info, i'm sure. i don't have the time this morning to google it.
now i'm off to the woods with my trusty chainsaws!
DM
Old 02-04-2009, 10:30 AM   #9
Everything I've read online would suggest that 50 gallons is MORE than enough.
Home Depot says that 50 gallons is about right. One of the commentors on this Yahoo post said that a 60 gallon tank was more than enough for their family of SEVEN!
But when I just do the basic math: Let's say two showers at 12 minutes each, with water flowing at about 2 GPM -- that's 48 gallons right there...my entire tank! That doesn't take into account the First Hour Rating of, I believe, 70+ Gallons for my heater. But I'm not convinced it heats quick enough for back to back showers.
Is it possible that my wife and I take unusually long showers? Is 12 minutes that long?
Thanks again,
Michael
Old 02-04-2009, 10:36 AM   #10
the Musigician
ok, i'm back with a truckload of hardwood to saw up later. i googled this--> Low flow showers usually operate about 2.246 gallons per minute (gpm). The national average for shower head flow rates is 2.6426 gpm
so i guess i was close.
what type shower head do you have?
if you could wait 10 to 15 minutes between, you'd probably see a difference.
Old 02-04-2009, 10:37 AM   #11
the Musigician
just an fyi, my shower is usually less than 5 minutes. it don't take THAT long to scrub, wash yer hair and get out....-=chuckle=-
DM
Old 02-04-2009, 10:39 AM   #12
Argh! I hope this isn't the conclusion I reach after all this.....that we just need to take shorter showers.
I'll take a look and see what kind of showerhead we have. If it's not low flow, I'm sure replacing it will help.
Thanks everyone.
Old 02-04-2009, 10:43 AM   #13
the Musigician
in your typical dual element heater, the top one kicks in to heat the top water to keep it 'always' available, once the desired temp is reached, the bottom kicks in and heats the rest. now... if you don't have kids or elderly (scaldguards highly recommened if so) then you should be able to get longer showers by increasing the temp on the tank's 2 thermostat settings for the elements. at 130 or 135, you will increase the length simply by having hotter water to mix with the cold. Po) oh heck with it, get the dam scaldguard anyways, you'll love how it stops toilet shock and pressure loss! hehehehe
DM
Old 02-04-2009, 10:51 AM   #14
the Musigician
of course, there will be a monetary penalty for this solution.
DM
Old 02-04-2009, 10:56 AM   #15
Well, I would definitely turn up the temp on the water heater before getting a bigger tank, needless to say.
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Tankless water heater questions shadango Plumbing 8 11-12-2008 08:10 PM
Tankless Hot Water Heater - One Fauset Does Not Have Hot Water? vsheetz Plumbing 1 10-29-2008 12:18 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
