My Washer Has Low Hot Water Flow...help - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2009, 03:42 PM   #1
My washer has low hot water flow...help
My house was bought a few years ago and the hot water going into the washer worked fine, up until about a year ago. Since then, I've just been washing clothes with cold water. I tried narrowing down the problem, first by checking if both the hot and cold rubber hoses had flow going to the washer. Those were fine. Where I seem to be having the problem is where the hose to the hot water hammer arrestor is connected to. I opened the valve and the water flow coming out is very low.
What do I need to do now? Is this due to a faulty arrestor?
K1NJO is offline   Reply With Quote
Old 12-17-2009, 06:30 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,710
Ayuh,... I was going to mention the screen strainer inside the hose fitting on the washer itself,...
But,...
You've got something I've never run across before...
Can you hook directly to the washer, by-passing that set-up,..??
Bondo is online now   Reply With Quote
Old 12-17-2009, 09:27 PM   #3
It doesn't appear to be a problem with the washer. The problem seems to be somewhere along the path of the water heater to the valve where the hose connects.
Old 12-17-2009, 09:51 PM   #4
Shut your water off and take any shutoff valves apart. It may be a washer has disintegrated and fallen off and pieces are blocking flow.
hayewe farm is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Low Water Flow Wayada Plumbing 2 06-14-2009 06:03 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
