My Tub Is 1-1/2" Away From The Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2012, 11:50 AM   #1
My tub is 1-1/2" away from the wall
I just had to remove the tile walls from my bathroom and want to install a surround. My issue is that the tub sits about 1.5 inches away from the wall. What are my options to address this? It is a cast iron tub that I would prefer not to replace. I tried to upload a pic but this site won't let me.
Cornbread 52 is offline   Reply With Quote
Old 08-05-2012, 11:54 AM   #2
Rewards Points: 582
fur it out to meet tub rim..install m /r board then your tub walls...pics would help greatly
Old 08-05-2012, 11:59 AM   #3
Fur it out? Sorry I'm a car guy, not a plumber.
Old 08-05-2012, 12:05 PM   #4
Rewards Points: 582
pic not real good...but put furring strips..wood...on your existing studs then install moisture resisting drywall ...that should bring you up to tub rim..then install new surround that should cover tub rim...
Old 08-05-2012, 12:06 PM   #5
Rewards Points: 13,300
Just nail 2 X 2's to the studs using siding nails to bring out the wall 1-1/2.
You are using a nail on enclosure, right?
If it's a glue on then we have to go to plan B.
Old 08-05-2012, 12:20 PM   #6
I was planning to put green board behind the surround which would make up half an inch, but that still leaves an inch to go. The surround I was looking at doesn't go to the ceiling and the is still some sheetrock left in place.
More photos
Old 08-05-2012, 12:46 PM   #7
Plan b?
Flat wall 1/2" Transition Suggestions shelzmike Drywall & Plaster 4 03-02-2012 08:13 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Slip-on diverter with less than an inch of 1/2" copper nipple out of the wall jamesm113 Plumbing 3 07-24-2009 12:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
