Old 10-07-2007, 06:40 AM   #1
My Toilet Tank won't fill up!
I do not have the floating ball in my toilet tank, but the other kind.
I can flush it sbout once per day because the tank won't fill. The water supply IS turned on.
Any ideas?
Dan
Toilet Humor is offline   Reply With Quote
Old 10-07-2007, 07:02 AM   #2
Send a message via AIM to Marlin
You have a fill valve like this?
I'd shut the water off, remove the supply line from the bottom of the toilet, if you have a flex point it into a bucket, a hard line put a tray under there and hold your hand around the top of it. Then turn the valve on a second to see if you have pressure.
If you have pressure change the fill valve (fluidmaster). This is the most likely culprit.
If you have no pressure remove the line from the speedy valve and repeat. If this gets you pressure change the supply line to the toilet.
Marlin is offline   Reply With Quote
Old 10-07-2007, 10:42 AM   #3
I would suggest replacing the fill-valve with a fluidmaster 400A fill-valve. They are under $10 and have great installation instructions. You can check the supply valve while you have it apart to install the valve.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-07-2007, 10:46 AM   #4
I looks like it is a HushFlow apparatus. I don't have all the hardware that I've seen in other diagrams... does anyone know this brand?
Dan
Old 10-07-2007, 10:57 AM   #5
If you have a flex supply test it like I said above. If you don't, don't bother testing it. A brass tube supply won't clog up, it was a little early when I replied. If you rule out a flex line as a culprit replace that Hush Flow assembly with a Fluid Master ballcock. They go for under ten bucks and include easy to follow directions.
Old 10-07-2007, 02:58 PM   #6
Thanks!
I just installed a new unit- I'm psyched!
Take care.
Dan
Old 08-19-2011, 05:47 PM   #7
When I turn off the water at the bottom and turn it on again it starts filling up...any suggestions as to what might be causing this?
Ladyneedshelp is offline   Reply With Quote
Old 08-19-2011, 05:55 PM   #8
Lightfoot's Avatar
replace the rubber diaphram if it's a fluidmaster. if it's not a fluidmaster, i'd change it out. around 10 bucks
Lightfoot is offline   Reply With Quote
Old 08-19-2011, 11:18 PM   #9
Lightfoot's Avatar
34,736 views. I didn't realize this thread was that old when i posted.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
1 piece toilet leaks at brass gasket below flapper texaslady Plumbing 1 10-02-2007 03:40 PM
Toilet flushes slowly, but no visible clogs... poorboye Plumbing 4 09-13-2007 12:02 PM
Toilet Tank fills slowly ronniecr Plumbing 3 09-08-2007 05:29 PM
Piece on bottom of toilet tank won't seal Squeeealer Plumbing 1 07-14-2005 09:13 PM
