My Toilet Sounds Like A Foghorn - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2005, 11:02 AM   #1
Question
My toilet sounds like a foghorn
When the toilet is flushed, it makes a sound like a foghorn. Can anyone tell me why and how to fix this? Thanks
katzpjs is offline   Reply With Quote
Old 02-13-2005, 11:55 PM   #2
PRO
Glasshousebltr's Avatar
Replace the float valve assembly.
It's a pole to the left in the tank with a rod and a float comming off it.
Bob
glasshousebuilder.com
Glasshousebltr is offline   Reply With Quote
Old 02-15-2005, 07:41 AM   #3
Thanks, Bob. Can I install one of those new float-less ones?
Old 02-15-2005, 09:05 AM   #4
Contractor
I've had some pretty bad luck with the floatless valves.
Teetorbilt is offline   Reply With Quote
Old 03-15-2005, 06:26 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
Install a Fluidmaster 400A float-cup type assembly (about $6 bucks at a big box). Comes with easy, illustrated installation directions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-15-2005, 03:33 PM   #6
LJD
Reformed Pirate
Are you sitting on the toilet when it makes the foghorn sound? Is there any odor that you have found to be associated with the sound?
Just trying to gather all the information I can before I give you my answer!
I use only Buffalo tools, and I'm always happy to loan them out!
LJD is offline   Reply With Quote
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
