Old 05-21-2011, 08:55 AM   #1
pwa
my toilet is possesed
After installing a a.s. 4049 3 or 3 1/2/gal the bowl will not clear unless the handle is held down.Things I have checked wax obstruction(remove and reinstall),trap obstruction( placed bowl in tub and simulate flush),water level (full as possible),Tried low profile seal inside tank to bowl,install flapper with stryafoam,all holes under rim open, I assume venting is fine,it worked before. Thanks for and advice in advance.pwa
pwa is offline   Reply With Quote
Old 05-21-2011, 09:26 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Shorten the chain on the flapper as short as possible and still allow it to function, and try that to see if it helps solve the problem.
Sometimes it's just the little things.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-21-2011, 03:55 PM   #3
pwa
no slack in chain and flush arm is centered over flapper
Old 05-21-2011, 05:36 PM   #4
YOu don't want the water refilling the tank spattering over the flapper, that will force the flapper closed too early.
Fixing this can be tricky and require some makeshift baffle.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Toilet wont drain chazlew Plumbing 11 02-27-2011 11:08 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
