My Tile Floor Is Warm - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2005, 11:46 AM   #1
my tile floor is warm
I have a 2-story house built in 1966 on slab in Northridge, CA. I have Copper piping. My kitchen & corridor tile floor from Wtr Htr in Garage to kitchen sink is too warm in different areas along the 40 foot run. Is hot water leaking at multiple areas under the slab. Hot water at kitchen sink takes 5 seconds to get hot(40 foot from heater). In other parts of the house, it take 30 to 40 seconds. I discovered this warm floor in the summer when I walked bare foot. No sign of wetness or moisture on floor. I shut off the hot water valve at the heater during the night 10 PM to 5 AM to check. Still the floor is warm at 5 AM. I don't have a heater pump. Can you help?
minahanna is offline   Reply With Quote
The Following User Says Thank You to minahanna For This Useful Post:
lascruces (10-05-2012)
Old 12-13-2005, 04:00 PM   #2
rspainhower's Avatar
Do you have radiant heat under your tile floor?
rspainhower is offline   Reply With Quote
Old 12-13-2005, 05:17 PM   #3
I do not know. How can I find out. Nothing is indicated at the circuit breaker panel, no thermostat, ...
Old 12-13-2005, 08:08 PM   #4
I'm just stirring the:
CGofMP's Avatar
Is the home an Eichler perchance?
Eichler Homes were a contemporary styled home featuring open living areas, flat or slightly pitched roofs that sometimes incorporated a sharp point above a entryway. Eichlers have extensive glass areas much of which is at the top or near the peak. They do not have an attic or any crawlspaces.Eichlers are on a concrete slab, and introduced the use of hydronic radiant panel heat for the heating system. They were built from 1950 - 1973 in Northern California, between San Rafael and San Jose. I understand they built them down south where you are.
There are approximately 11,000 homes in these areas.
To me Eichlers look more like a carport with doors than a home :-)
If you have an Eichler its real possible you have a radiant heat floor.
CGofMP is offline   Reply With Quote
Old 12-31-2005, 12:28 PM   #5
Unhappy
I am having the same problem. I also live in Northridge in a two story townhome. I think the first tile began to get warm 2 weeks ago and now its half the kitchen and part of the breakfast nook. We also tried turning off the water heater while we went to work but it did nothing. HELP!
nikomie is offline   Reply With Quote
The Following User Says Thank You to nikomie For This Useful Post:
Old 12-31-2005, 04:11 PM   #6
jproffer's Avatar
Rewards Points: 714
People pay good money for this feature to be installed in their floor. Go with it:D
jproffer is offline   Reply With Quote
Old 01-02-2006, 06:13 PM   #7
Rewards Points: 77
I know this may sound strange but how about talking to the neighbors if they have similar homes they may have information about the "problem"? They may even be nice folks.
Zero Punch is offline   Reply With Quote
Old 01-23-2006, 02:20 PM   #8
More of the kitchen floor is getting warm. I noticed my 1-year water heater is working non-stop. I turn the heater water valve off during the night and when out at work. Heater manufacturer confirmed that there is a leak. I am more convinced that my copper piping has numerous pin holes and a major re-piping has to be done.
Old 01-23-2006, 06:04 PM   #9
joed's Avatar
Rewards Points: 12,940
Sounds like a broken water line under the floor. Try turning of the water from the heater and see if the floor cools off.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
