Is This My Shower Drain Stack? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2012, 09:42 PM   #1
Rewards Points: 87
Is this my shower drain stack?
This is my unfinished shower in my lower level that is a daylight basement.
I am trying to figure out if this pipe that have noted is the tack for that showers drain or something else.
hellonoko is offline   Reply With Quote
Old 02-07-2012, 09:53 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Just taking a guess but I think it might be just a vent for the basement.
You could have someone run water up stairs and listen to find out if water runs in the drain/vent
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-07-2012, 10:01 PM   #3
Rewards Points: 13,250
Really need to work on getting rid of all that old steel pipe. If it's not leaking now it will at some point and it closes up on the inside from rust.
Old 02-07-2012, 10:07 PM   #4
Rewards Points: 87
@Plumber101
Not sure what you mean that is the slab there it goes into... It just goes right up into the second level and out the roof. It isn't connected to any other drain systems as far as I can tell.
@joecaption
I am going to get rid of all the metal supply. Possibly the metal drains...
But the cast iron in the slab.. ehhhhh.
Old 02-07-2012, 10:10 PM   #5
Rewards Points: 560
Ok then it's just a vent for the basement drains.
Old 02-07-2012, 11:56 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
So did you have to stand in the corner and stare at steel and cast iron as a kid for punishment?
Just wondering since that seems to be your standard line to any piece of steel pipe that shows up in a post!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Tags
drain , plumbing , shower , stack
Shower drain problem SUPPO Plumbing 5 02-05-2012 12:04 AM
Tie stack to main drain rtoni Plumbing 3 04-21-2011 07:49 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Basement Shower Drain Problem! cleveland1980 Plumbing 16 01-29-2010 01:49 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
